JAHR tool???
The 75-76 2.0 throttle body is calibrated the same way as the 73-74 2.0 throttle body. You find the pins that get connected together when the throttle is closed, and you rotate the switch until they are connected together
only when the throttle is closed (and up to about 2 degrees of throttle opening).
--DD
