My salvage titled car has had a low idle problem for a long time. It runs great at anything above idle. Here is what I've done:
Checked vacuum hoses for leaks
Checked fuel pressure
Replaced a visibly bad injector
Swapped to a known good distributor
Swapped to a known good ECU
Adjusted valves
Replaced and adjusted throttle switch
Tried 3 different MPSs
Fiddled with the ECU knob
Unplugged the intake air temp sensor
Measured the hot and cold resistance of the CHT
Set timing
Replaced plugs, cap and rotor
What I have not done, but suspect:
Injector seals
Injector flow test
Here is what it does:
It idles fine when cold. Once it warms up the idle adjustment screw has to be all the way out for it to idle at about 800-900 RPM. After a spirited drive, the idle will drop to 4-500, and sometimes it dies. After a minute or so of idling it restabilizes at about 8-900 RPM. (this is with the adustment screw all the way out still) It doesn't sound like it's missing, just idling too slow.
Could bad injector seals cause this problem? I know it's not a main pelenum vacuum leak because that causes a high idle. Would a leak at just one or two injectors imbalance it enough to cause a low idle?
(Yes, I have read Brad Anders' site repeatedly)
