Dave-O
Mar 10 2005, 06:43 PM
First semi-complete picture of my home-made drop-links. I still have to track down some jam-nuts. Can't wait to finish this sway bar project next week during my spring break.
David
Mueller
Mar 10 2005, 06:47 PM
look nice...I bought a set similar to those from a fellow club member a few years back....when I parted out the car, those endlinks had a bunch of slop in them after only a few hundred miles...that is if those are the cheaper brass lined ends and not the better teflon/hardened steel units....
Dave-O
Mar 10 2005, 07:00 PM
QUOTE (Mueller @ Mar 10 2005, 06:47 PM) |
look nice...I bought a set similar to those from a fellow club member a few years back....when I parted out the car, those endlinks had a bunch of slop in them after only a few hundred miles...that is if those are the cheaper brass lined ends and not the better teflon/hardened steel units.... |
Thanks for the warning. I'll keep my eye on them. I only have about $20 invested in these things so it won't break my heart to have to "upgrade" to some higher quality rod-ends.
David
Jeroen
Mar 10 2005, 08:16 PM
you need to fab something so you can turn the rods
Aaron Cox
Mar 10 2005, 08:22 PM
QUOTE (Jeroen @ Mar 10 2005, 07:16 PM) |
you need to fab something so you can turn the rods |
drill a hole through them. then you can stick an allen wrench in there, and turn the rod....
MattR
Mar 10 2005, 08:26 PM
Aaron, you significantly weaken the part by drilling a hole through it. Think about the surface area you've exposed.
You can either grind two shallow notches and fab your own "drop link adjuster tool" out of a flat piece of steel shaped like an H, or you can add material and use channel locks to adjust.
Mueller
Mar 10 2005, 08:27 PM
I was thinking vise-grips
two opposing flats might be easier to do instead......
Aaron Cox
Mar 10 2005, 08:31 PM
btw...what size heim joints are those? 8mm?
also... were female heim joints cheaper than males? just curious
MattR
Mar 10 2005, 08:32 PM
Aaron, dont make me break out the text book. Any other engineers want to chime in here? Im not saying what the other company has isnt sufficient, Im just saying one is stronger then the other. If you have the option to do either, i'd go with the stronger one. But thats just me.
bondo
Mar 10 2005, 08:37 PM
Drill out a big nut, slide it on, and weld it in place.
Aaron Cox
Mar 10 2005, 08:38 PM
QUOTE (bondo @ Mar 10 2005, 07:37 PM) |
Drill out a big nut, slide it on, and weld it in place. |
best solution yet!
Dave-O
Mar 10 2005, 08:44 PM
QUOTE (Mueller @ Mar 10 2005, 08:27 PM) |
QUOTE (Jeroen @ Mar 10 2005, 07:16 PM) | you need to fab something so you can turn the rods |
ding ding...we have a winner. That was my plan. Since i will never be putting any load on them i don't think they should be too tough to turn. If it doesn't work well i cold possibly tac-weld a big nut onto it. It's all experimental right now.
QUOTE |
also... were female heim joints cheaper than males? just curious |
The price was about the same, but with the rod section in the center I have much more control over length. I still have like 4 feet of rod stock that i could make any length needed.
The ends are 3/8"...just under 10mm. You can bash me all you want for using 'merican hardware but it's just easier to find around here. I can run down to the local tractor dealership and find a HUGE selection of standard hardware in various grades. Works for me...
David
Dave-O
Mar 10 2005, 08:45 PM
QUOTE (bondo @ Mar 10 2005, 08:37 PM) |
reading my mind...didn't get it typed in time!
TimT
Mar 10 2005, 08:46 PM
Actually you should be able to adjust these just using your fingers.
when the car is on the ground and you have settled the suspension, adjust the length of ONE of the links such that there is no preload..of course it helpd to have the ride heights and corner weights dialed in before you adjust the drop link length
ChrisFoley
Mar 10 2005, 09:45 PM
Does one end have a left hand thread?
Any corner balancing needs to be done before attaching one of the drop links to make sure there is no preload. Then adjust the length until the bolt slildes easily through the rod end.
I find it easier to use male ends and make the rods out of larger diameter stock, drilled and tapped. Left and right hand taps are cheap and easy. Then Aaron's idea of a hole for an allen wrench is ok because of the additional cross-section.
rick 918-S
Mar 10 2005, 11:20 PM
Those should work out nice. Keep the photos coming.
Dave-O
Mar 11 2005, 12:12 AM
QUOTE (Racer Chris @ Mar 10 2005, 09:45 PM) |
yes sir, one left and one right
QUOTE |
I find it easier to use male ends and make the rods out of larger diameter stock, drilled and tapped. |
good idea...might use it if i ever have to make another set
QUOTE |
Those should work out nice. Keep the photos coming. |
pictures will start again when i start wrenching on saturday
David
skline
Mar 11 2005, 12:33 AM
Well Dave, looking at your avatar, I can see you need this sway bar. Good luck with it.
