sdoolin
Nov 11 2015, 09:42 AM
I had to change out the relay board that came in my car for one of the spares that I got with the deal - fixed a fuel pump issue I was having.
But - the board that I am using does not have the threaded insert for the post that secures the relay board cover and - I cannot sort out how to remove that threaded insert from the board that came in the car. Looks like I almost have to cut it out, or somehow otherwise damage the board to remove it?
Any/all help appreciated.
JeffBowlsby
Nov 11 2015, 11:53 AM
Cover just slips on. Post/nut not needed or recommended.
sdoolin
Nov 11 2015, 03:01 PM
Thanks for the reply, but with all due respect sir Bowlsby (not being flip - I really mean it) I'd like to utilize the post/nut. My cover isn't perfect and just slipping it on does not secure it. I have reinforced the area of the cover under the nut with a small thin gauge bit of sheet aluminum to provide better "bite" for the nut.
Certainly someone has been down this road before? I don't want to destroy the "bad" relay board that still contains the threaded insert if at all possible.
JeffBowlsby
Nov 11 2015, 03:20 PM
Embedded nut cannot come out without destroying the board, its cast in place. Trade your board for another that has the nut.
sdoolin
Nov 11 2015, 03:22 PM
Dang it. I have 2 other spares and yet neither have the cast in nut?
Thanks so much, I guess I will get more creative...
914Sixer
Nov 11 2015, 04:29 PM
Check the hardware bins at Lowe's or Home Depot. You might find something to be creative with.
bandjoey
Nov 11 2015, 06:55 PM
1/8" thick bunji cord. String. Epoxy a nut to the board. Etc. looks do count as well as function.
whitetwinturbo
Nov 11 2015, 07:30 PM
This is post is just nutty............happy VET day
Dave_Darling
Nov 11 2015, 11:29 PM
Drill and heli-coil?
--DD
JamesM
Nov 11 2015, 11:43 PM
QUOTE(sdoolin @ Nov 11 2015, 02:01 PM)
Why replace the board again, just find a better cover.
EdwardBlume
Nov 12 2015, 07:51 AM
Plastic bag and wonder bread tie clip. When you hear it get sucked into the fan.. reapply.
Actually, I agree that having a cover is more of the point.
sdoolin
Nov 12 2015, 11:35 AM
Thanks everyone. I like the drill/helicoil and the epoxy a nut in place ideas. I also (strangely) like the plastic bag and tie wrap idea simply because of the sucked into the fan comment.
Good stuff.
I will either helicoil or epoxy a nut, depending on what I find out in the shop...
sdoolin
Nov 22 2015, 09:42 AM
So I very carefully epoxied a nut onto the cover post holder on the board (JB Weld). Seems very solid - and I even dabbed a little flat black paint on it so as not to be completely obvious. Works well and with my reinforced cover, things are nice and snug.
Now (of course) the car won't start. Fuel guage snaps to full when key on (the tank is full), alternator light glows red, but the fuel pump does not cycle and I get a faint click when I try start the thing.
Sheesh...
bandjoey
Nov 22 2015, 06:28 PM
When I do something like that it's usually a simple "I forgot" to reinstall something. Regulator or harness plugged in tight or ?.
Tom
Nov 22 2015, 09:53 PM
I superglued in an insert, sorry I can't remember where I got the insert. Measured the dia. of the insert, drilled out the hole slightly larger, and set it in with Loctite gel control superglue. It isn't so runny and is easier to work with. Great for gluing on cue tips on pool cues also.
Tom
