Cross drilled brake lines!Thats good stuff
-Cross Drilled Brake Lines-
Want improved braking? Why just cross drill those rotors? Introducing KaleCo cross drilled brake lines! Improved airflow through lines provides superior brake cooling. Brake fluid is exposed to cool moving air, almost instantly reducing heat, and providing shorter stopping distances! All lines are made of quality latex. Brake lines come in: Black, Yellow, Red, or Blue. Please specify color when ordering!! Warning!! You must replace ALL brake lines at once as to prevent mismatched pressure feedbacks! You may mix colors.
