QUOTE(Mikey914 @ Nov 18 2015, 03:11 AM)
Try the screw (that has a nut on it) at the bottom of the door. It should close the gap nicely. You want it to just touch.
Mark
I believe you mean this one on the passenger door. It is attached to the front rail that the window moves up and down in. It is in a slotted hole and in a position to adjust without removing the door card. not sure how adjusting the front will seal the rear.
Click to view attachment These 2 are connected to the rear rail, are in slotted holes and can be tinkered with without removing the door card (something to remember for next time
. I think I will try these 2 1st.
Click to view attachmentAre the above 2 spots the only adjustment locations?
Click to view attachmentThere seems to be 2 other adjustments: Currently in the middle hole just behind the crank is a bolt that is acting as a STOP. As you crank up the stop hits the gear and stops the window. The other one I am not so sure about. You can barely see a white rectangle there is a bolt on it, but does not appear to be in a slotted hole. Not sure what it would do anyway.
