mb911
Dec 3 2016, 02:37 PM
Click to view attachment Son did some work on the car. He has never welded before but not much to screw up so perfect learning for him.
jd74914
Dec 3 2016, 03:01 PM
That's awesome! I have some great memories welding with my dad and grandpa as a kid.
mb911
Jan 7 2017, 02:04 PM
Well haven't worked on it much lately as been concentrated on shipping the 1-5/8" heat exchangers. I received some goodies though some 2.2 S pistons for my 2.4 , my heads redone and ported to 36mm ports both courtesy of Henry @supertec.
I will resume some welding this week and looks like I need to send the crank out for inspection probably case for a line hone both going to supertec.. Guess I need to make some new products to fund this.
Click to view attachment Click to view attachmentClick to view attachment
Steve
Jan 8 2017, 02:40 PM
QUOTE(mb911 @ Jan 7 2017, 12:04 PM)
Click to view attachment Click to view attachmentClick to view attachmentLookin good!!! Can't wait to get my heat exchangers!!
mb911
Jan 8 2017, 02:54 PM
QUOTE(Steve @ Jan 8 2017, 12:40 PM)
Yours are 1 of the sets pictured..
Steve
Jan 8 2017, 11:28 PM
Yea!! Can't wait!!
JmuRiz
Jan 9 2017, 09:03 AM
QUOTE(mb911 @ Dec 3 2016, 12:37 PM)
Well...at least he has a good instructor!
jmill
Jan 9 2017, 10:44 AM
Are those S Pistons ceramic coated? I swear, every time I look at one of your threads it costs me money.
mb911
Jan 9 2017, 11:31 AM
QUOTE(jmill @ Jan 9 2017, 08:44 AM)
Yup.
mb911
Apr 20 2017, 09:02 AM
All the major structural repair has been done so now floor pans and cleaning up underside and repair some bad areas (i know there are allot of those
Finished up rear suspension etc. Plated everything.. See some progress.
Click to view attachmentClick to view attachment.
PanelBilly
Apr 20 2017, 09:41 AM
I see holes in the floor pans. Are you going to make lower seat mounts to give you more head room?
mb911
Apr 20 2017, 11:34 AM
QUOTE(PanelBilly @ Apr 20 2017, 07:41 AM)
No needs a rear floor pan so this is the easy way for me to get in there and weld em up.
pete-stevers
Apr 20 2017, 08:26 PM
I sure like six threads
It warms my heart!
mb911
Apr 23 2017, 08:27 AM
QUOTE(pete-stevers @ Apr 20 2017, 06:26 PM)
It warms my heart!
Things are coming together still slow but that is fine by me
mb911
May 4 2017, 07:54 AM
So made some progress this week. I welded a bit more small repair areas. Waiting on a firewall and floor pan section and then I will finish the underside this summer for sure.
The case came in yesterday from all the machining. Looks great now lots of cleaning.
May 4 2017, 01:44 PM
Tomorrow I'm sending you that long promised sideshift transmission.
Tried to clean the undercoating off and the steam pressure washer gave out after a couple minutes.
Justinp71
May 4 2017, 01:53 PM
QUOTE(pete-stevers @ Apr 20 2017, 07:26 PM)
It warms my heart!
Totally Agree
mb911
May 5 2017, 05:49 AM
Thanks everyone.
The trans I currently have is a core at best as the ears were broken off at some point and the gear lube is black as black can be so Mark you are helping me out big..
Yesterday I removed one of the 4cyl engine mount on driver side. Fixed some more rusty areas.. I am plugging away.
Talked to Henry on more parts for my engine. Going to have about 6k in parts but the engine will basically be new. The crank and bearings are the most expensive part and would make all of you sick. Good thing no timeline on this.
mb911
May 5 2017, 11:51 AM
Spent a little time today blending the inner long I fabricated on the driver side. Turning out nice. I will post pictures soon..
mb911
May 11 2017, 01:53 PM
Here are some pictures and updates.. Everyday been making a little progress. Go out at 5am work until 5:45 then leave for work so it is slow going.
The case was at supertec. The fan assembly I restored myself.. Almost done on driverside rust repair. Passenger side next week then waiting on firewall and a driverside patch panel from a member that is down for the count with a shoulder injury for a bit.
Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=604
095]
mb911
May 16 2017, 09:19 AM
So made some progress as the bottom flange lip on the tunnel was rusted . I need to just grind and blend it now along with punching a hole in it for wire pass through. Lots of grinding in my future
I also took some time to make some of the engine sheet metal. These 2 pieces and took about and hour.
restore2seater
May 16 2017, 11:54 AM
Any thoughts on selling engine sheet metal for a 6 conversion?
mb911
May 16 2017, 12:15 PM
QUOTE(restore2seater @ May 16 2017, 09:54 AM)
I think i might but not just yet...
mb911
May 17 2017, 05:52 AM
Finished off the tunnel repair.
mb911
May 17 2017, 10:01 AM
Made the hardest of the sheet metal pieces today. It is 2 pcs as i am not sure how else to make it without a die or having it look horrible. I will probably draw these up and have laser cuts made.
mb911
May 18 2017, 02:09 PM
Click to view attachment Another piece done.
Soon bigger sections will be done. Once the floor pan is on it will really look like headway is being made.
mb911
May 23 2017, 01:28 PM
Finished all 5 pieces of sheet metal just need to drill and sand a few spots. Finished gt reinforcement kit on passenger side, have to grind and blend a bit.. Welded -6 oil line hook from mcmark on
Firewall soon as soon as tygaboy is healed he will ship me his and the rear floor pan will go on.
Received my latest batch of replated parts/ hardware today including my head studs for the engine and misc parts. Thats always fun..
I have about 4 more weeks that i will put in a 3-4 hours a week amd then a break for a while as i have some vacation coming soon.
mb911
May 23 2017, 05:06 PM
whitetwinturbo
May 23 2017, 09:04 PM
.............love the look of new zinc plate
mb911
May 24 2017, 05:41 AM
QUOTE(whitetwinturbo @ May 23 2017, 07:04 PM)
Mee too. Best part is that it is so inexpensive.
mb911
Jun 3 2017, 10:24 AM
Found some pictures of my last conversion today.. Some of the details i want to do on this build. Though i am thinking black instead of red.
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment
11tenths
Jun 3 2017, 12:37 PM
And I thought clear filter tops so you can see the stacks was my idea.
May I ask what material you found to withstand the fuel/possible backfire environment?
-Harry
mb911
Jun 3 2017, 12:45 PM
I used plexiglass from glass shop.
mb911
Jun 3 2017, 12:48 PM
Click to view attachment Click to view attachmentClick to view attachmentThese cars i owned inbetween 914s and built the turbo from a 77s and built a 3.2 ss turbo engine.
mb911
Jun 3 2017, 12:53 PM
Just went out for another hour and fixed the passenger side tunnel flange, lower corner of passenger long.
My issue is the stamping done on the bottom of the passenger long(inner) is really not easy to replicate so i need to think on that as that is what the floor pan welds too. I can patch it but I really only need a 1.5" 90 degree piece about 30" long but have to have the stampings to lool right.
Jun 3 2017, 06:22 PM
The 964 looks so generic next to the turbo. It's partly the color but it really seems like porsche went the wrong direction with the cosmetics on that car. JMO.
horizontally-opposed
Jun 3 2017, 09:31 PM
This pic has me wishing someone would do rain hat carb covers in real glass. Just so sexy to look down on the trumpets...
mb911
Jun 4 2017, 05:28 AM
914rubber maybe a new product.
forrestkhaag
Jun 5 2017, 12:17 PM
We have injection moulding experts in the Urban Workshop / I will do a little asking on what would be the best Lexan or other clear plastic to form / most likely a copy of my rain hats....... hmmmmm $$???
GeorgeRud
Jun 6 2017, 11:57 AM
I'd think you'd want to use something non-flammable. I remember seeing the mess an original -6 was when a backfire ignited a stock plastic air box and the melted plastic was dripping down the carbs. Ugly to say the least!
JmuRiz
Jun 6 2017, 02:42 PM
+1 what GeorgeRud said.
My engine mechanic isn't a fan of pipercross filters because of this as well.
They flow great, but if you get them soaked in fuel and backfire...it's a REAL mess.
mb911
Jun 18 2017, 07:25 AM
My engine sheet metal is getting powdercoated right now. Floor pan goes on this week. Drilled all the areas for the plug welds. Sprayed cold galv on all thw areas that are hidden. Did a bunch of grinding and blending.. Almost over the hurdle.
mb911
Jun 20 2017, 08:29 AM
Here is a bottom long replacement.. You can see some of the previous owners repair. Gotta clean all of that up yet. Making good headway. Rear half floor pan starts tomorrow
mb911
Jun 21 2017, 05:46 AM
Click to view attachment And floor is tacked in.
mb911
Jun 21 2017, 05:47 AM
GeorgeRud
Jun 21 2017, 06:24 AM
Looking great! New metal always looks nice and the welding looks sublime.
mb911
Jun 21 2017, 06:54 AM
QUOTE(GeorgeRud @ Jun 21 2017, 04:24 AM)
Funny thing is I bought that floor pan 2 years ago.. Unreal it took this long to put it in place..
whitetwinturbo
Jun 21 2017, 10:09 AM
Jun 21 2017, 11:37 AM
QUOTE(whitetwinturbo @ Jun 21 2017, 12:09 PM)
He's waiting on a piece from me
tygaboy
Jun 21 2017, 01:23 PM
QUOTE(mepstein @ Jun 21 2017, 10:37 AM)
...and on a chunk of floor from me, too. It shipped yesterday!
