mb911
Apr 2 2018, 11:01 AM
QUOTE(bbrock @ Apr 2 2018, 08:56 AM)
The suspense is killing me.
What did you wind up doing to strip paint and clean? I know you said wire brush to start. It is looking really nice!
Wire brush on the 4.5" grinder and then also the. Norton rapid strip wheel on the 4.5 inch grinder. Then DA with 80 grit.
bbrock
Apr 2 2018, 11:18 AM
QUOTE(mb911 @ Apr 2 2018, 11:01 AM)
Thought that might be the case. Those Norton discs are awesome. I bought a box (actually Black Hawk brand but I can't tell the difference) and love them. If it stops snowing long enough to put my tent up, I'll be wheeling the car out for some serious blasting and stripping.
mb911
Apr 2 2018, 11:35 AM
Yes they work well use the wire brush for the corners.
mb911
Apr 5 2018, 05:58 AM
Well cleaned/sanded/ ground more on the entire driver side of the floor this week and its ready for primer. Next week return to the passenger side and finish that side of the floor up.
mb911
mb911
Apr 5 2018, 05:59 AM
Cairo94507
Apr 5 2018, 06:08 AM
Ben - That is looking very nice. Love seeing them nice and clean on the bottom.
Tdskip
Apr 5 2018, 08:50 AM
That is a cubic boatload of work...
defianty
Apr 5 2018, 09:16 AM
Nice and clean - good work Ben.
mb911
Apr 5 2018, 11:19 AM
mb911
Apr 6 2018, 06:03 PM
Finished the rack rebuild. Its better then previous .. I might look for a spare
mb911
Apr 6 2018, 06:39 PM
And for my own inspiration here is my last 6 and the 911 before a full turbo conversion
Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=645
672]
mb911
Apr 16 2018, 01:15 PM
Slow progress lately. I did do more grinding and then removed 1 headlight. I did buy a fender from Garold that is near perfect and a factory replacement that Glenn and Garold cut off a parts car for me
To replace the Hodge podge passenger fender.. This will make it much nicer.
Bought some metal etch to apply in a few areas..
Coming along now..
mb911
Apr 19 2018, 05:47 AM
Dug out the decklid as I start to head into the bodywork stages.
Also hammered out all the welds on the flares and then applied a very thin coat of the kevlar reinforced water impermeable filler about 1/16" thick on all the seems inside and out of the flares.
mb911
Apr 24 2018, 06:49 PM
Super busy lately but spent some time hammering out the body as close as possible to be within max thickness of 1/16" filler. Then spread the kevlar reinforced filler to ensure no pin holes then sanded all the seams and applied some evercoat filler, cured and then I use a large bastard file to cut down the filler close. I will next sand a little bit and apply another thin coat of filler.. This is a nice way to ensure a nice straight blend..
Mark Epstein sent me some goodies including a nice porsche badge for the rear panel ala GT.
Also got my sons 944 running this weekend and making progress on all fronts..
mb911
Apr 26 2018, 11:22 AM
A few pictures. Went wide on the band of filler to make sure it fills evenly.
mb911
May 1 2018, 02:04 PM
Push through the majority of the underside so I could get the primer on yesterday.. Turned out pretty good. Now it will be to get the top side done and back to bed liner underneath..
mb911
bbrock
May 1 2018, 02:36 PM
Milestone! Sweet!
mb911
May 2 2018, 05:48 AM
QUOTE(bbrock @ May 1 2018, 12:36 PM)
Milestone! Sweet!
Yes feel good about that.. Gonna need some areas touched up but at least its protected..
mb911
May 3 2018, 06:02 AM
Sanded and prepped the exterior .. Will prime tonight. Yes there is a skim coat of filler.. Its not 1/2" thick so don't worry. The plan is to prime and let all the body work sit for a year or so.. This will allow any shrinking to happen over that period(winters are particularly hard on that) .. Once this is all primed the work doesnt stop still have the frunk to work with.
Cairo94507
May 3 2018, 08:04 AM
Nice seeing it looking ready for primer.
mb911
May 3 2018, 08:58 AM
About 3 years in the making to get to this point..
bbrock
May 3 2018, 11:17 AM
Are you going to spray with it on the rotisserie? I'm starting to try to envision the logistics involved when my car gets to this stage. I still have a month or so to watch yours and see how it's done.
mb911
May 3 2018, 12:35 PM
QUOTE(bbrock @ May 3 2018, 09:17 AM)
Yup gonna do the rotisserie for priming.. I still need to prep engine compartment and frunk.. Trying to prime manageable chunks..
I want it rolling this summer.. Underside is gonna get the bed liner before too long.
PanelBilly
May 3 2018, 01:54 PM
Tape off all the places that you will mount parts to before you do the bed liner. This is especially important where there’s nuts welded in for the suspension. You can cut and peal the liner off when its dry, but it’s easier to do it when its been taped off first. Are you doing the engine bay too?
mb911
May 3 2018, 02:22 PM
QUOTE(PanelBilly @ May 3 2018, 11:54 AM)
Thats good advice.. I will do that for sure..
Engine bay I am undecided.. It would be nice to keep it uniform.. But at the same time gloss paint makes it nice too
May 3 2018, 02:28 PM
QUOTE(mb911 @ May 3 2018, 04:22 PM)
Gloss is much easier to clean than a textured finish. I’ve read of guys using a single coat of clear to make the bed liner easier to clean.
mb911
May 3 2018, 02:42 PM
QUOTE(mepstein @ May 3 2018, 12:28 PM)
Another good idea.. Proper prep would be a must..
raynekat
May 3 2018, 06:02 PM
QUOTE(mb911 @ May 3 2018, 07:58 AM)
Sometimes these projects can really leak out into the future for sure.
mb911
May 4 2018, 05:07 AM
QUOTE(raynekat @ May 3 2018, 04:02 PM)
Its about the journey.. Primed some more last night..
mb911
May 4 2018, 05:08 AM
Dion
May 4 2018, 05:22 AM
Pretty. Just like a factory “body in white” ready to be customized.
Very nice indeed.
Cairo94507
May 4 2018, 06:46 AM
Nice indeed. That just has to make you feel good.
mb911
May 4 2018, 06:53 AM
QUOTE(Cairo94507 @ May 4 2018, 04:46 AM)
It does.. Though I know where more body work needs to be done it makes me feel better that the metal is protected from the humidity
restore2seater
May 4 2018, 07:34 AM
What kind of primer are you using?
mb911
May 4 2018, 07:44 AM
QUOTE(restore2seater @ May 4 2018, 05:34 AM)
Ppg epoxy..
bbrock
May 4 2018, 07:57 AM
Are you going to spray high build/surfacer before you leave it to shrink? I think PPG says you can cover it without sanding within 10, after which you have to sand. I was thinking on mine I could spray epoxy, then follow with surfacer, then relax, let it shrink, and take my time blocking. But I don't know if that really makes sense.
mb911
May 4 2018, 08:00 AM
QUOTE(bbrock @ May 4 2018, 05:57 AM)
Brent,
Probably hold off for now. There is still extensive body work to do with the flares, welding in pin holes, etc.
I will do the bedliner in certain areas and underneath so I can mount the suspension.. Then next winter do more body work..
bbrock
May 4 2018, 08:01 AM
QUOTE(mb911 @ May 4 2018, 08:00 AM)
Brent,
That makes sense.
tygaboy
May 4 2018, 08:09 AM
Ben - Congrats! Primer and bed liner...mmmmm.
(I can only dream about that part of my build.)
Thanks for the motivation.
Chris
mb911
May 4 2018, 09:49 AM
Thanks guys.. I appreciate all the cheering and help over the journey.. Still would guess 2-3 more years to completion.. At the least.
May 4 2018, 10:08 AM
QUOTE(mb911 @ May 4 2018, 11:49 AM)
Let’s not forget some parts you’ve brought to production.
mb911
May 4 2018, 02:03 PM
QUOTE(mepstein @ May 4 2018, 08:08 AM)
That's very true along the way allot parts side tracked me..
David Billo
May 4 2018, 02:46 PM
QUOTE(mb911 @ May 4 2018, 07:07 AM)
...Its about the journey.. Primed some more last night...
Yeah, that's great to be at that point in the project!
Ben, I'm interested to know the details of your paint setup, compressor, gun, etc. I'm contemplating doing my own paint eventually as well (probably year or two away) and trying to get a handle on what I'm going to need. It would be nice to avoid buying an insanely huge compressor just to paint one car. From what I've read, 80 gal, 5HP is recommended for non-stop spraying a typical car, but it seems easy with our cars to break it up into smaller sections and get away with a smaller compressor.
May 4 2018, 03:09 PM
You can also rent a compressor if you're thinking its a one shot deal.
Getting it in primer always makes a project look closer to finished!
congrats Ben, see you soon
mb911
May 4 2018, 04:24 PM
QUOTE(David Billo @ May 4 2018, 12:46 PM)
I have a 10 year old 60 gal 5hp sanborn compressor, a Sata hvlp gun along with an old binks hvlp gun. Painted 6 or 7 cars with this setup.
Works well.
GeorgeRud
May 4 2018, 08:58 PM
Ben, I don’t think you get to sleep between this project, your son’s car, your great parts, and work. I’m sure it’s great seeing the chassis finally in primer!
mb911
May 5 2018, 06:21 AM
QUOTE(GeorgeRud @ May 4 2018, 06:58 PM)
Yes sort of a balancing act..
As part of my full time job we have 4- 1 week dictated vacations per year and this week was one of them and you can see I made progress. Things won't happen as fast but expect bed liner within the week but have allot of other things to get done..
I really need to finish the engine and get it running on a stand.. Want to do a little muffler testing as well.
