QUOTE(bbrock @ Dec 20 2018, 06:51 AM)
QUOTE(JmuRiz @ Dec 20 2018, 07:40 AM)
I'm leaning towards using that sound deadener in my interior (since I stripped the floor tar to check for rust...none found!, and took out he engine bay pad).
How did you like working with the product you used? Any tips for rollers to use etc?
I used the thicker version of that same Noico deadener and it is very easy to work with. You can cut it with scissors and it it is very pliable to form into all the crevices etc. You can buy a good metal roller on Amazon for about $10. Noico has their own that looks like a good design. I made the mistake of not buying one because I figured I could pick up one of those wooden wallpaper seam rollers locally. I learned that I'm old and those seam rollers are not cheap Chinese plastic. It worked but the roller edge is sharp so you have to be careful or it will cut through the foil on the deadener. They are also flimsy so I broke the first one toward the end of he install and had to buy another. Better to order a good roller when you order the deadener.
I actually used the rubber/foam block sanding block for mine..
And
@tdskip here are a few thoughts.
I feel that I am good with allot of different aspects of restoration of cars but by no means an expert in all areas
I can paint fairly well
Build engines as I did that in a former life
Fab and weld (my profession)
That said the car I fixed would have been scrapped by 99% of the folks on this board.. It is a frankenstein made from Mark, tygaboy,and my cars . My biggest suggestion is find a car as rust free as possible. If you find one with rust learn to weld 1st.. Now learning to weld is not a 5 minute job . it takes hours. My students take on average 90 hours of real weld time before they are ready to weld things correctly. Most body shops don't even weld correctly and the icar certs are an absolute joke so keep that in mind. Then start repair of the car. I feel very strongly that most of the cars people scrap should be saved. People like
@mcmark are fully of capable of fixing these cars and we should be saving them.
Other then that take your time.. Lots of time
Keep in mind in my 3 years I also developed 12 914 specific parts so that did take time from the build..
