Here is the deal. I ordered new pistons for for my M calipers and of course the listing was WRONG. Information listed on the web site showed the pistons for the pin type caliper which they are. Part that is listed is really for LATE cup pistons. Seems like the early calipers had something called a knock back. I am assuming that is the spring in the piston of the caliper. If the late calipers do not have the pin and use the cup piston why not remove the pin and replicate the late caliper? I gently worked the pins back and forth not damaging the piston bore and removed them. Test fitted the pistons and they work just like they should. When you drop the pistons in you can feel them forcing air out of the chamber.
Is my thinking flawed and did I waste a caliper?
