QUOTE (Gearren @ Mar 11 2005, 01:54 PM) |
I have a 73 2.0L with stock weber 40idf carbs. |
QUOTE (Gearren @ Mar 11 2005, 02:13 PM) |
Also I live in North Carolina. |
QUOTE (jwalters @ Mar 11 2005, 06:04 PM) |
just look at all the posts on here about people having nothing but trouble from thier fi..... |
QUOTE (SirAndy @ Mar 11 2005, 06:14 PM) | ||
yeah, but that's because most people don't understand how the FI works ... once you know what each D-Jet compnent is doing, it's easy to diagnose and fix. after a initial overhaul, my 1.8L D-Jet ran without a problem for 3 years and now mueller is running it. still going strong. now my carbs on the other hand ... Andy |
QUOTE (jwalters @ Mar 12 2005, 04:37 PM) |
I just like carbs--plain and simple--cause they are plain and simple--once they are bought, modest cash outlay at best--over the next 20 years of never ever having to buy or put on another induction part will more than recoup the expense--many times fold-- |
QUOTE (jwalters @ Mar 12 2005, 05:39 PM) |
Have you REALLY not done anything to the fi except a carb spray on a stuck idle valve?? that is hard to fathom... |
QUOTE |
You mentioned you really don't care about mileage anyway--but this and cooler running go hand in hand--and a cooler running motor makes more power. |
QUOTE (Carl @ Mar 12 2005, 11:33 PM) | ||
Some good advice here, but I question one statement:
I don't think this is the case. I was taught that a hotter engine develops more power due to greater thermal expansion. The upper end of the heat range being limited by the potential of burned valves, detonation and possible breakdown of the oil. Colder engines produce less power because they're not extracting as much expansion energy out of the fuel due to less optimal air/fuel ratios, cam overlap or spark timing. Isn't this correct? |
QUOTE (jwalters @ Mar 12 2005, 08:29 PM) |
Man I have always loved the T3's--which one you got--square, fast, or notch?? If you say notch I am going to die--those things are just about unobtanium-- Man, if only they put K-jet on it---ohh boy--what you can do with that!! Got any pics of it??? |
QUOTE (jwalters @ Mar 12 2005, 08:45 PM) | ||||
you ARE correct--if it is a water cooled motor---A hot water cooled is equal to a cold air cooled--most performance minded w/c use a 160 thermostat--cool water and hot oil are best for these engines--160 x 2 = about normal head temps at speed on an aircooled--optimal for these engines is cold oil and hope the air in the atmosphere is cool .. |
