QUOTE(rhodyguy @ Nov 23 2015, 03:42 PM)
You should not have to force the linkage. Do the pass side ISAS and see if you can then bring the idle down with the drivers side. The purpose behind this is finding out if one of the drop links is holding both of the carbs open a bit. One side off of a stop lets the carbs follow suit. If you don't have a/the correct device to measure the side to side flow you're working in the dark. Post pictures of the carbs and linkage you are using.
OK, I'm a total noob when it comes to carbs, but surely I can learn
I looked up the Redline website, and found a section ford IDF Carburetors/ Low Speed Circuit Tuning. Is that the ISAS you talk about? What sort of device do you need to measure the side to side flow?
This is from the service ticket when I first picked it up:
"Tech attempted to balance carbs. Right carb on cylinder #3 had too much flow (twisted throttle plate), can't balance properly. Test drove, ran too rich. Removed #170 jets and installed #130 jets. Test drove, ran better. Removed idle jets and replaced with #60. The idle jets were worn to between #63 and #66. To adjust and set better, would need to tune with custom jet sizes."
This is a '74 2.0 that is supposedly rebuilt to a 2.2 with 44 IDF carbs. I've added some
pics
First time I've added pics, so sorry they are sideways. In the first one, you can see the fuel leakage at the bottom of the carb. The second shop I took it to said that carb would need to be replaced because of the leak.
