We can refinish those Mark.
The problem with those is "very" dirty metal underneath. They were not prepped properly "at all". The zinc is doing it's job. Zinc is a sacrificial coating so it will corrode before the base metal does. What you are seeing with the chicken-pox is the zinc pulling the impurities from the very dirty base metal.
After going to SEMA and speaking with all of the various reps there, I will almost "guarantee" you that those are made in China. Calipers are very difficult to plate properly. They have to be positioned a certain way in the tank etc. Also, the hexavalent chromium used on the outside is totally wrong or non-existent which brings me to one final hypothesis... with the RoHS initiative in Europe, they may be a European product that is using a hexavalent substitute and, what you see is what you get. I think the previous diagnosis is more accurate however, we've seen this here with calipers that weren't prepped properly. It looks more like a base metal issue vs. a dichromate issue. This brings me back to China and a bad plating job. Zinc is the best but, if they can't use it in Germany now because of RoHS, then these are China calipers.
Same problem with the last ones though... they are later model calipers meant for cars with booster circuits (cup style pistons vs. contoured tops). You should really just get some period correct M-Calipers and we can make them work. We got a set in yesterday from some guy in the LA area... says he's into cars.
