QUOTE(toon1 @ Nov 28 2015, 08:23 PM)
A bad aar usually causes backfiring because a lean condition.
It has a heating element in it that heats up a metal coil that expands when hot and contracts when cold.
When cold it opens to let air bypass, when hot, no air.
When it fails it stays open letting more air in causing a lean condition and the engine will backfire.
When the engine gets hot it will close and run normally.
They usually don't cause fuel pump issues.
Are you making that up or has this happened to you?, because this is not my experience of how these components work. My D-Jet 2.0L has never ever backfired.
The AAR is a controlled air leak allowing more air into the intake only when it is cold enough outside to allow the AAR to open, then it closes as the engine warms. At the same time, the cold start valve will open allowing more fuel into the intake for the same short period of time, all to help start the engine until it reaches operating temp. More fuel and more air is not a lean condition for the engine conditions. If a backfire happened, something else was also awry.
"Cold enough" means the 10s and 20s (F) for air temps, but it just does not get that cold here in the SF bay area, so the AAR and CSV should never even come into play and could effectively be disconnected here locally. The specific temp range for the CSV is determined by the thermoswitch in the CSV circuit, values are on Brad Anders page and are dependent on which thermoswitch you have installed.
The fuel pump should not be affected by a shorted out AAR wire, but if you suspect it may be defective in some way, test its flow rate to verify its function.
