QUOTE(screenguy914 @ Dec 1 2015, 11:12 AM)
QUOTE(moldygreg @ Dec 1 2015, 10:45 AM)
Hi All-
I'm getting tired of wheeling the teener around on a set of cheapo HF wheel dollies and then jacking the car up each time to remove the dollies.
Any "affordable" recommendations for a set of hydraulic wheel dollies? $400 seems reasonable, but don't think I could justify twice that for a set of Go Jacks.
Many thanks in advance!
From your message, you're referring to the simple wheeled, formed sheet metal platforms that HF sells. FYI, HF also sells a GoJack-like wheel dolly (currently $100 ea.), but with a mechanical ratcheting lift mechanism instead of a hydraulic ram.
http://www.harborfreight.com/1250-lb-capac...olly-61917.htmlNote: It appears this is a newer design. The older version can support a wider tire (+9") and is painted red. Can't speak for the construction on the newer version.
Maintenance and repair is something to consider. Hydraulic versions (GoJack and equiv.) may have o-ring/seal issues at some later date. I imagine GoJack should have replacement parts (please confirm). Not so sure about the imported versions.
MHO,
Sherwood
(no affiliation)
Thanks for the message. Correct, I have the formed sheet metal platforms and they're a pain to get the car on/off.
The hydraulic version seems so much easier to move the car around, so I'm seeking any recommendations on what's an affordable option -- I'm now thinking maybe the ones from Eastwood, but did not see that HF had a newer design out. Will check out that.
Greg
