Silver Surfer
Dec 1 2015, 05:01 PM
Cracked the side mirror today adjusting it in the cold.
Has anyone replaced the mirror glass successfully? I see AA carries a replacement glass and seal. Has anyone used these? Other suggestions?
Thanks!
Big Len
Dec 1 2015, 05:05 PM
I brought mine to a local glass shop. $15 to cut a new piece
Kraftwerk
Dec 1 2015, 05:29 PM
A local glass shop cut mine as well.. $10, but it took then 2 tries.. the gasket is the tricky part..good that a new one is available through AA.
ClayPerrine
Dec 1 2015, 05:31 PM
Local glass shop put one in for me.
EdwardBlume
Dec 1 2015, 06:20 PM
Not tough but the gasket gives out easily...
Silver Surfer
Dec 1 2015, 06:53 PM
Thanks guys. I'll give the new AA gasket a shot and see about sourcing the glass locally. I guess I needed another winter project...
914Sixer
Dec 1 2015, 08:13 PM
Sierra Madre has the glass too.
Elliot Cannon
Dec 1 2015, 10:41 PM
All three of SLITS' mirrors are badly broken. And he didn't even have to touch them.
SLITS
Dec 2 2015, 08:09 AM
QUOTE(Elliot Cannon @ Dec 1 2015, 08:41 PM)
Harrumph .... don't need them anyway as the car is so fast that I don't worry about what is BEHIND me.
ClayPerrine
Dec 2 2015, 08:16 AM
QUOTE(SLITS @ Dec 2 2015, 08:09 AM)
You can't outrun ugly.
Elliot Cannon
Dec 2 2015, 09:31 AM
QUOTE(SLITS @ Dec 2 2015, 06:09 AM)
Jeffs9146
Dec 2 2015, 10:32 AM
FYI
I found that the AA mirror glass was a bit thinner than the factory and I needed to add a spacer behind the mirror to keep it from vibrating.
GaroldShaffer
Dec 2 2015, 10:47 AM
I found when replacing the glass that it helps to warm up the gasket a little before you pull it if you plan to re-use it. Made it easier to remove and reinstall. YMMV
gandalf_025
Dec 2 2015, 11:18 AM
The original windshields aren't much better after all this time.
I got mine out of the car fine..
Broke it carrying it to put it in a safe place. DOH.
Damn doorknob....
rjames
Dec 2 2015, 11:28 AM
Who sells new gaskets? (other than AA)
boxstr
Dec 2 2015, 11:35 AM
I have used a local glass company to have new glass cut. It best it you tape yours and take it in so they can get it to the correct size and shape. You don't always need to replace the gasket. If you carefully remove the gasket and glass you should be okay.
I might have a new glass at camp.
Craig at CAMP
boxstr
Dec 2 2015, 04:32 PM
Pm sent.
Craig
Harpo
Dec 2 2015, 05:42 PM
QUOTE(914Sixer @ Dec 1 2015, 06:13 PM)
The mirror that I purchased from Sierra Madre didn't fit so be careful
Silver Surfer
Dec 2 2015, 06:15 PM
QUOTE(Garold Shaffer @ Dec 2 2015, 08:47 AM)
Good tip! I'd love to reuse the original gasket if I can. I think I'll have a repro gasket on hand just in case.
Silver Surfer
Dec 2 2015, 06:20 PM
QUOTE(boxstr @ Dec 2 2015, 09:35 AM)
Craig at CAMP
Thanks Craig! Responded to your PM. Let me know if you have any new glass on hand I'd be happy to swing by camp. I thought Camp 914 was in West Linn for some reason, I'm actually 10 minutes away in Oak Grove.
If you don't have any on hand could you give me the name of the glass company that you used? Thanks!
