$25,000 OPEN TO OFFERS. Located in Los Angeles. All the work is done and this is a beautiful car, that would cost more to duplicate.
Jeff 310 430-6212 or ginettag4@verizon.net or PM me.
1974 Porsche 914 -Started life as a 1.8L and now is a 1950cc 130hp
This was sold in 1974 in Tucson AZ and lived in AZ all its life until I got it. It sat outside in Tucson for 20+ years -- fortunately the desert climate kept it from rotting away and it was it great shape when it was found. The resto was done over the last 12 months.
Here is a description of the car as it sits now
Completely Rust free in rare optional L041 Black over Black interior.
The car looks great and drives perfectly. The car has 9/10 paint and 9/10 interior.
Here is a list of what was done to it in the last 12 months.
Engine/Trans/Brakes/Suspension
The engine was rebuilt about 1,000 mi ago with a 96mm big bore kit, SCAT C-25 cam, new Webber 40mm IDFs and all top quality bearings and gaskets.
Fuel Injection removed and replaced with Dual 40mm Webber IDF's that have been thoroughly tuned to make very strong power while avoiding the flat spots and drivability issues associated with some carb conversions.
Engine
Well tuned. Runs smoothly without any drivability issues while making significantly more power than a stock 2.0L. Output is around 130hp at crank.
The 1.8L case and crank is the starting point for most 2L race engines for the short stroke -makes more power and torque. The output is approx 130 hp exceeding the output of the 914/6 or the era.
- Fully Rebuilt 1000mi ago
- 1.8L crank and case
- 96mm Pistons and Cylinders (approx - 1950cc)
- Scat C25 "Hard Core" Cam
- New dual Webber 40mm IDF's with velocity stacks and new air cleaners. 52 Idle Jets, 1.15 Main Jets, F11 Emulsion Tubes.
- Melling Oil Pump
- Bosch 205 AA Distributor (Running the Mechanical advance only as the curve is well suited to the cam and carb combination.)
- New: Plugs, Wires, Points, Condenser, Cap, and Rotor
- New Air Filters
- New High Torque Gear Reduction Starter
- Fuel tank removed, professionally cleaned, and repainted. All new fuel lines from the tank to the carbs.
- Just adjusted the valves
- Bursch Exhaust (Sounds really good.)
- New Engine Mounts
Transaxle 5 Speed Side Shift
Rebuilt and less than 200 miles on it - The side shift 901 transaxle shifts precisely and smoothly.
- All new bushings using BRASS shift linkage bushings where applicable
- New Transmission Mounts
- Fresh GL5 oil change
New Clutch
Repacked CVs
Wheel Bearings replaced Front and Rear Axel Bearings replaced
Brake Pads Replaced
New Front Shocks
New Rear Shocks
New Rear Springs (stock rate) -- Old one sag after 40 years
New Yokohama 205/60R15 Tires (Fit perfectly with no clearance issues.)
Stainless Steel Brake Lines
Body - 88K ON CHASSIS
No rust what so ever at this time.
There was some minor rust in hell hole area that has been professionally repaired and then coated with POR 15.
Freshly sanded to bare metal with glass out repaint to an extremely high standard. The black paint looks like you can swim in it and the sides are smooth enough to give a perfect reflection without any waves or distortion.
The bumpers are painted a satin black to offset the gloss black of the body.
New Rubber upper front bumper
Ugly 1974 bumper overriders removed
Rubber seals and light gaskets were recently replaced with new parts from 914 Rubber.com, including window seals and the expensive targa top seal. The door alignment is perfect and the doors open and close smoothly with the correct "thunk".
Headlights go up and down as expected
Front Fog lights replaced with driving lights and work in unison with the bright lights
The under body is perfect and painted -- as clean as the top.
Heater/defroster/ventilation works as delivered
New Windshield
Interior
Everything works properly and looks great.
Both Seats are reupholstered
New Carpet
New Dash --from 914 Rubber- better than new
All Gauges work - racing tach installed - but stock one included
New Fuel Tank Sending unit
Radio is brand new with retro look -- but new Tech including IPOD in
Owners Manual
Jack
Redone Door panels
Targa Roof is 9/10 and all seals are new
MOMO suede Wheel -
Negatives:
Brakes squeak when cold
Wheels could use a polishing
No Sunvisors
