It was me. But I had a 914/6 dash frame to start with. I cut a hole for the vent on the left side, and spliced in the vent opening on the right side.
I had to move the emergency flasher switch to the right of the column, as there was only room for the headlight switch, fog light switch, and the ignition switch on the left.
Also, I had to make a 914/6 column. I used a early 911 column, cut the mounts off of it, and welded it to a 914/4 mount. It works, but I had to trim down the 911 clamshells to clear the instrument cluster.
Click to view attachmentClick to view attachmentClick to view attachmentIt was worth it to get the key moved to the correct side. If someone made the stamping for the area around the ignition switch, it could be done using a stock 914/4 dash frame.
