So, I get working on my car today since it's been running rough and wouldn't start today... While adjusting the points Ifind that the screw hole into which the screw that holds them down goes is stripped, so after fiddling with it for a while I go buy a 009 type unit and replace it. Then I decide to clean my jets while I'm at it, since it wasn't running well, and find that one of my idle jets is missing!
Are 40ida3c and 40idf idle jets interchangeable? I could pull one off of my 911 if it would work.
A 009 should work, right?
