capitolatim
Dec 3 2015, 09:54 PM
As I was installing a Turbo Tie rod kit on my recently acquired 70, I found the right hand securing strap(?) had a big twist. No idea how this could have happened?
Looks like everything is square but would like some advice.
Cheers
Tim
914Sixer
Dec 4 2015, 07:59 AM
What did the front pan look like? You normally see bends like that from the car being hit in the front corner of the fender and pushing everything back. Look at the chassis specs and take some measurements under there. You will probably find some side to side difference.
bandjoey
Dec 4 2015, 08:29 PM
also the globs of seam sealer / tar looks like something to cover up damage. Hopefully it was repaired ok and this is not a problem.
r_towle
Dec 4 2015, 10:11 PM
Your front end may not be square.
Dave_Darling
Dec 4 2015, 10:47 PM
It's trying to get away from that Facet Clacker pump.
--DD
rhodyguy
Dec 5 2015, 01:34 PM
That fuel line is going to fail. Prob at the worst possible time.
