Joe Bob
Dec 5 2015, 05:22 PM
Back in the day, when 914 owners converted the rears to five lug and beefier calipers they lost the 914 e-brakes. Some upgraded to 911 shoe type inside the brake hat.
Others used a small mechanical caliper. Can't remember what manufacturer.
Anyways, I am looking for a small mechanical caliper that can accommodate a 6.5 mm disc. This will be for a motorized bike application, if interested.
Does anyone have any leads? I guess I could always call Wilwood on Monday when they open....but they can be pricey. Or ErC at PMB.
Thanks
Dec 5 2015, 06:09 PM
Mechanical mountain bike caliper? Probably around $20-25.
Joe Bob
Dec 5 2015, 06:10 PM
This is what I am working with.
ClayPerrine
Dec 5 2015, 06:18 PM
Dec 5 2015, 06:25 PM
Avid mechanical caliper. Probably find some "take offs" at a bike shop for a couple dollars. eBay, ect.
bigkensteele
Dec 5 2015, 06:43 PM
QUOTE(Joe Bob @ Dec 5 2015, 04:10 PM)
Are you planning on using the sprocket as your rotor? If so, you may want to rethink that unless you will be running a chain that doesn't need to be oiled. Such a thing may exist these days. I don't know.
Elliot Cannon
Dec 6 2015, 12:34 PM
You don't need a brake. Just put your feet down.
messix
Dec 6 2015, 02:21 PM
the chain is going to be a interference issue let alone oil on friction surface.
Mike Bellis
Dec 6 2015, 04:12 PM
I have a pair of spot calipers but can't use them as they won't fit over my 930 rotors. I decided to go with 911 parking brake setup instead.
Dec 6 2015, 04:15 PM
You could use a mt bike disk on the front and a bicycle caliper brake on the back.
