Hey everyone, haven't been on here in a while but I'm working on the car again and have a question.
I'm replacing the input shaft seal on the transmission and I have a seal kit. the input shaft seal in the kit has a smaller outer diameter than the seal that is currently in the transmission.
The seal in the transmission right now has these markings
"KACO DS 22.40.11 / 16 / 2"
The seal in the kit is an Elring 22.2x40x12/17
The inner diameter of the seals appears to be the same.
I attached some pictures so you guys can see what I'm dealing with. Anyone run into this issue before and know where to source the seal with the larger outer diameter?
