14Maschine
Mar 13 2005, 12:46 PM
It was a beautiful sunday morning. A morning you just have to cruise. I shortly found a little place in my shift pattern that it dosnt like. On my way into 2nd gear. You can push it up and to the right futher then you could before. Where the shifter is promptly stuck. Takes a little tug to get out. ANnnnnnd now my car wont seem to go into 5th. Could this be my shift linkage? Has anyone experianced this problem before? I know there are alot of experianced 914 guys on here. Help me keep my teener goin!
GWN7
Mar 13 2005, 01:00 PM
Check the linkage to see if it's come loose anywhere and check the shifter bushings to see if they have cracked and fallen out.
14Maschine
Mar 13 2005, 01:26 PM
Thank you sir. The advice is very much apreciated.
GWN7
Mar 13 2005, 03:31 PM
There are 61 parts in the 70-72 shifter assembly and 36 parts in the 73-76. Any one of them could cause the problems or add up to what you have described. The main problems with shifters is the following parts,
the 1970-72 cars:
New Ball Cup Bushing
3 New Firewall and Shift Rod Bushings
2 New Shift Rod Ball Bushings
For 1973-76 cars:
New Firewall Shift Bushing
New Rear Shift Rod Bushing
2 New Shift Coupler Bushings
2 New Shift Coupler Cone Set Screws
It could also be something as simple as a loose (or broken) motor/trans mount. If those are out of wack they will also throw off your shifter.
While your down there check the oil level in the trans too....
