On the 70-71 there is a center vent in the dash top. I am currently in the process of redoing my dash and need to know how to remove the plastic part of the vent that is above the dash.
Any help is appreciated.
tom...
QUOTE (Special_K @ Mar 13 2005, 12:32 PM) |
Are we talking about the defrost vents (windshield)? Because I don't recall any vents in the center of the dashboard. |
QUOTE (markb @ Mar 13 2005, 03:37 PM) |
Center vent, 70-71, two small screws on the under side of the dash. If you're going to re-use it, be careful, thay get fragile. |
QUOTE (Joe Ricard @ Mar 13 2005, 04:52 PM) |
Nope take it apart is about the only way to do it. Yes I had 2 1970 models. they both have the center vent. |
QUOTE (Carrera916 @ Mar 13 2005, 05:00 PM) |
yeah....I've a '71 and you have to pull the top part of dash out, flip it over and you'll see two tiny flushed screws there. BE VERY CAREFUL when taking it off or tightening it up....ask me how I know! I will have to pull mine out again as the plastic piece came loose at one end....probably stripped! j |
QUOTE (Tom73 @ Mar 13 2005, 08:57 PM) |
I am starting to understand why everyone is running around with a trashy dash cover. The work involved in redoing the dash is just too much. Just buy a cheap dash cover, throw it on and away you go..... |
