QUOTE(rgalla9146 @ Dec 13 2015, 06:32 PM)
QUOTE(Mark Henry @ Dec 13 2015, 05:13 PM)
I can show you a 72 911 tank that was cut open.
There is a bit to them, but they are just a can with a bit of internal plumbing and baffles. The oil enters the tank and is then plumbed through the oil filter, back into the tank and out onto the top of the screen baffle. The main baffle is just a SS screen, which is about 1/3 of the way down from the top of the tank. The oil exits towards the rear of the tank bottom. You could make a simple can and use an external oil filter mount, but you must keep the tank screen/baffle as that is what separates the air from the oil.
There is nothing high pressure about the tank, the highest pressure would be the restriction of the oil filter.
I looked into doing this myself, it would be a fair bit of work to get it right but it is doable.
If you were to fab a tank, mild steel would be fine as long as the tank is sealed and always filled with clean oil. The issue would be rust through from the outside, the top being the most prone.
If you are good at welding and don't mind a bit of extra weight I bet you could MIG weld a steel tank. SS or AL would be better, but then you need a TIG welder.
In the end I found a deal on a complete DWD tank set and I scooped it up.
A mild steel tank will rust out from the inside too.
This is especially so with cars that sit for long periods.
The water condensate pools on the bottom of the tank as well as in droplets on the upper inside.
This is probably why the factory copper plated the tanks.
Well OK, but the factory tank I opened had no plating on the inside, it also had no rust in the bottom of the tank, even though from the outside in it had countless holes in the top of the tank.
I do believe it had a surface treatment along the lines of ospho, but not copper.
That said I'm not interested in a debate.
I looked totally into this, if you are a competent welder and have the equipment I would have built either an Aluminum or stainless tank.
If you can get a hold of a DWD tank to scope out, they are IMHO the best tank out there. Below is his old website:
http://www.dwdesignwerks.com/oilsystem.htmAlthough he stopped making them long ago, when he made a move to Australia, he still lurks here from time to time. His name is Don Welch and goes by member name BigD9146gt.
If he's not too busy, I bet he'd give you some pointers on tank design. I'd try to PM him directly.
BTW Patrick sell a tank that looks a lot like the DWD tank.
I can't confirm this, so it could be hearsay, but I've heard they are not quite as good as a DWD tank.
