Highland
Dec 10 2015, 09:06 PM
I was wondering if I can replace the board in 1.7 TPS and use it in a 2.0 stock D-jet system.
Are the boards the only difference?
JeffBowlsby
Dec 10 2015, 09:54 PM
Not interchangeable, they rotate in opposite directions. Both replacement boards are available.
davesprinkle
Dec 10 2015, 11:31 PM
As Jeff said, these sensors rotate in different directions. And you cannot swap boards between sensors because the wipers are different as well.
Mikey914
Dec 11 2015, 11:52 AM
You can bend the arms slightly to make them follow a slightly different (unworn) path. or better yet replace them.
Highland
Dec 11 2015, 12:18 PM
QUOTE(Mikey914 @ Dec 11 2015, 09:52 AM)
Replacement arms are available?
NJ914
Dec 13 2015, 07:09 AM
I have a similar issue with my TPS. Board is scratched but more of the issue is the arms are bent a bit. Can you get new arms? Where? Does anyone have a photo of a 2.0 TPS with the arms in their correct position at idle?
BeatNavy
Dec 13 2015, 07:29 AM
I don't think I've ever seen just the arms for sale. Maybe put a WTB in classifieds for a whole TPS?
Mikey914
Dec 13 2015, 02:35 PM
No the arms are not available, but you can replace the board. I wouldn't try bending the "back" but the new board should solve your issue.
boxsterfan
Dec 13 2015, 08:47 PM
Everything you ever wanted to know about D-Jet here:
http://members.rennlist.com/pbanders/djetparts.htm
