Hi All,
Dumb question here but can't find the answer using search, maybe because it is obvious!
When replacing the rubber manifold connecting hoses, it looks like the two manifolds need to be removed and a new gasket fitted when reinstalling? If this correct or is there a simpler way to replace the rubber hoses. I did not want to go pulling the manifolds off, since I do not have new gaskets handy, only to find out there is an easy way. I did remove the old rubber hoses by scoring the top with a razor knife and then prying them apart.
Thanks,
Mike
