QUOTE(era vulgaris @ Dec 13 2015, 10:07 AM)
I was only curious as far as quality, but now I'm confused. When I did these on my old car, both were the same thickness. Is the T4 store indicating that you're supposed to use one of each thickness?
Anyone with the Tangerine Remote Oil Cooler Takeoff kit want to chime in as to which they used?
Also I'm surprised 914rubber doesn't make these. Unless I missed them, but I looked through the entire site.
I need the answer as well. I have the tangerine racing block off plate and was about to buy a set of seals from PP.
There is one set that is $$ and the other cheaper.
Was planning on getting one set of each.
As for the:
"Where do I get one of these with the correct threads for the sender switch location?"
I don't want to restart that argument, but there are some that believe that thread is actually metric.
I used a 10mm metric thread adapter to switch to 1/8NPT to screw my grease gun hose into.
You can see the adapter. It is the brass piece that is barely visible above the tin:
I believe this is the adapter I ordered:
https://www.pegasusautoracing.com/productde....asp?RecID=1832Most just thread the grease gun hose 3/8" NPT right into the case and call it good.
