Hi Guys,
I'd like to blast and repaint the steering column cover, which has become pitted (pic below). Is there a way to get the cover off without unbolting the unit from the steering shaft? If not, can you provide some tips for removal/replacement?
If I have to pull it off the shaft I will, but I'm not a fan of messing with things unless I have to .
I've searched the interweb and there's lots on changing the bearing, but I can't seem to find the process of removing the cover.
Thanks!
