1bad914
Mar 14 2005, 10:10 AM
I found a strut brace for the front, I'm at work so I can't post pics, but it looks like it mounts under the tops of the strut. The ends are u-shaped, one end spins freely, the other is threaded for adjustment. Does anyone have one like this, and how does it mount. I can post a pic tonight. It is anodized. Any thoughts?
ArtechnikA
Mar 14 2005, 10:34 AM
QUOTE (1bad914 @ Mar 14 2005, 11:10 AM) |
Any thoughts? |
it works by making your wallet lighter.
914's don't need front strut braces.
go have a look where the front bulkhead it is relation to the upper strut mounts.
911's need them because the front is just a big floppy box section -- but a 914 is not a 911.
Mueller
Mar 14 2005, 10:35 AM
the 914 has a built in strut brace, front and rear.....
the only reason to add an aftermarket one is if you cut the sheetmetal out for a larger gas tank/fuel cell
Eric_Shea
Mar 14 2005, 10:40 AM
No need... unless you are into tossin bills around. If so, PM me and I'll give you my address.
Jeroen
Mar 14 2005, 10:43 AM
strutbraces are for taildraggers... we don't need 'em
1bad914
Mar 14 2005, 11:50 AM
First off, my wallet is no lighter, I found this, as in no cost. Thanks for all the really positive comments.
Will it fit a tail dragger?
ArtechnikA
Mar 14 2005, 12:01 PM
we'd need to know more about it, because there are lots of strut braces around for cars that won't fit...
there aren't many cross-references in the catalogs available to me here because they've mostly stopped trying to sell those things to 914 owners. if it has a really broad length-adjustment range, it will probably fit a 911/912. i don't have the measurements from either a 911 or 914 available to me here either...
i'm not really in the market 'cause i already have one for the 911 (where they really are useful).
when you get a chance, post a picture, and the end-to-end dimensions, and you'll probably find it's useful to someone. there are a lot of 911 owners here, too ...
Jeroen
Mar 14 2005, 12:22 PM
post the pics, but I would be surprised if it fits a 914 and not a 911
