QUOTE(toolguy @ Dec 14 2015, 07:29 PM)
there are 4 fuses for headlights, high and low beam, left and right. .
when only 1 doesn't work, look at the fuses. . when both l & r don't work, look
at wiring . .
power wiring goes to the left [drivers side] first and then tandems over to the right side
I should mention it is an Engman fuse panel and has blade fuses. Also I frogged the fuses for the lights (Swapped left light fuse with right light fuse) and the problem did not change.
There should also be no corrosion as the wiring harness was rebuilt 10 years ago and is in good shape. But I will do a visual check of the loom and connectors.
