No but that shouldn't keep you from posting up some pics of it.
914itis
Dec 16 2015, 02:07 PM
QUOTE(76-914 @ Dec 16 2015, 02:57 PM)
Will do later .
r_towle
Dec 16 2015, 05:24 PM
It's not hard to do. Four posts, stand them up Two horizontal members go side to side Ramps bolt on front to back
You will need help. A strong set of backs and beer.
budk
Dec 16 2015, 06:13 PM
QUOTE(r_towle @ Dec 16 2015, 06:24 PM)
Having a helper is highly advisable.... however, I put my Bendpak 9000lb 4 post lift together by myself. I used an engine hoist and a cheap HF furniture dollies, it wasn't easy but it was do-able. Having a helper should make it relatively easy.
914itis
Dec 17 2015, 08:08 AM
Pics
914itis
Dec 17 2015, 08:11 AM
More
JmuRiz
Dec 17 2015, 08:26 AM
Oh you bought it used, yikes.
gandalf_025
Dec 17 2015, 08:33 AM
In case you are still looking for cable routing info...
Most of these 4 post lifts are the same.. 1 hydraulic piston under 1 rail with 4 cables coming off it. All 4 cables go to the end of that rail, with 2 coming back to the end of that rail and attach to the uprights on the reservoir end, the other 2 attach to the posts at the other end.
Longest cable goes to the post directly opposite the reservoir, width wise. next longest to the post next to the reservoir. Third longest is diagonally across from the reservoir Shortest is at the end of the rail with the reservoir.
That is the way the ones I have worked with are configured..
Your results may vary...
If you need pictures, let me know and I can try to get what you need
76-914
Dec 17 2015, 09:45 AM
Looks to be in pretty damned good condition. Shouldn't there be some rust on it? I wished I could have found a good used lift to fit my needs! Nice score Paul.
914itis
Dec 17 2015, 10:00 AM
QUOTE(gandalf_025 @ Dec 17 2015, 09:33 AM)
Thanks , I wil let you know .
914itis
Dec 17 2015, 10:01 AM
QUOTE(scotty boy @ Dec 17 2015, 11:00 AM)
Boy too bad you don't have any friends around. Looks like you need to put the kids to work
You are back, come on over. Not limited to 914...
914itis
Dec 17 2015, 10:04 AM
QUOTE(76-914 @ Dec 17 2015, 10:45 AM)
Yes very good condition, no rust or corrosion. I think I got a decent deal at $1200
I looked at the Chinese ones , the lowest was $1700 plus 600 shipping to my nearest terminal.
Porschef
Dec 17 2015, 10:40 AM
Giddy up, I gotta do a valve adjustment...
914itis
Dec 17 2015, 10:44 AM
QUOTE(Porschef @ Dec 17 2015, 11:40 AM)
Joe, Whenever you are ready .
Planing on installing it the first week of Jan.
Elliot Cannon
Dec 17 2015, 10:47 AM
QUOTE(76-914 @ Dec 17 2015, 07:45 AM)
It will have some rust on it as soon he puts the car is on it.
bulitt
Dec 17 2015, 02:13 PM
Paul- different manufacturer but should be similar.
