QUOTE(kupcar @ Dec 17 2015, 12:18 PM)
A+ for creativity across the board. Has anyone ever puked up enough oil to catch anything? I'm tempted to stick a k&n crankcase breather on the vent opening.
I posted a the same thread on here recently ,some said the K&N will oil mist your engine bay,I researched and found that you need to buy a can that has the largest fitting possible to work,I bought a D1 boy racer 600ml unit with 15mm fittings,appears there not many much bigger.
I then acquired a silicone reducer to go from my PMS filler neck (24mm) to 15mm on catch can.
I haven't decided if I go to a breather in the top of the can or run a hose back to the block,the fitting is already tapped so that's an option .
I presume the case is in some point of vacuum so this should pull the separated fumes from the can ??,the tank breather works this way so all should be good.
I don't have the option to run into the intake and don't want to besides.
