02loftsmoor
Dec 16 2015, 11:13 AM
Didn't some one post a tool that you can make to release the rear trunk torque springs??
Jacob
Dec 16 2015, 12:20 PM
914Sixer
Dec 16 2015, 03:20 PM
Quick and easy tool to make. Take an existing 1/2" breaker bar (mine happen to be broken) and cut a notch in it to fit trunk rod.
black73
Dec 16 2015, 04:33 PM
Pipe wrench works for me. Notice how the notch on Mark's tool resembles the jaws of a pipe wrench
r_towle
Dec 16 2015, 05:27 PM
10mm deep socket on a 6 inch extension
Slip socket over bar and unhook from under the wheel, slowly lean it toward the back of the car until done
Do both sides
Remove brackets which are still under tension so keep your eyes safe and hands....
Or you can just use a cut off wheel like SLITS does and cur them right in the middle....slightly more exciting but it also works.
02loftsmoor
Dec 16 2015, 10:36 PM
thank you for the information, it gives me some options
Wes
dangrouche
Dec 16 2015, 10:51 PM
broken Craftsman breaker bar, ought to be able to trade that one in for a new one
02loftsmoor
Dec 17 2015, 02:24 PM
QUOTE(dangrouche @ Dec 16 2015, 10:51 PM)
it makes a better spring tool than a breaker bar
02loftsmoor
Dec 18 2015, 03:27 PM
I was able to release the trunk springs, but are supposed to remove the side grills for better access??
ClayPerrine
Dec 19 2015, 08:03 PM
I made one out of a 12" crescent wrench. Just open the loop on the bottom.
About 6 months ago, I got a nice gift from Al Zim. He had two of the factory tools, and I now have one of them.
jim_hoyland
Dec 19 2015, 08:11 PM
QUOTE(ClayPerrine @ Dec 19 2015, 06:03 PM)
Picture ?
Jacob
Dec 19 2015, 08:15 PM
QUOTE(02loftsmoor @ Dec 18 2015, 04:27 PM)
I was able to work around them when I did it.
North Coast Jim
Dec 20 2015, 09:02 AM
QUOTE(02loftsmoor @ Dec 16 2015, 12:13 PM)
I made the following tool and it worked great. No Safety issue here.
02loftsmoor
Dec 20 2015, 11:15 AM
QUOTE(ClayPerrine @ Dec 19 2015, 08:03 PM)
Clay I need you to look at my hell hole, do I need to do more cutting?
Series9
Dec 22 2015, 03:21 PM
I enjoy "releasing" them with my plasma cutter.
skier2.0
Dec 25 2015, 09:38 AM
Nice drawing very similar to the factory tool I have, will post if I can find it.
NeunEinVier
Dec 30 2015, 12:44 PM
