[quote name='maddin' date='Dec 18 2015, 03:09 PM' post='2278387']
Hi there,
could somebody please point me in the right direction.Slightly confused which part to get...
I have a 72' 914 conversion with a 78' 3.0l with CIS.
I need the throttle linkage and the ball cup on the engine but not sure which one exactly...
Would that be the one?
Throttle linkage #90142302603Is there a difference in the linkage between carbs and CIS?
AA has a few different ball cups but none for a 78'..are they the same as the 77' model?
Ball cupsshould I get new bushings too?
Thanks
I bought ball cups from pelican the right hand thread ones are genuine and the left hand thread ones were aftermarket from memory.
I found there was wear in some and not in others,best to check and order the ones to replace the worn ones as they cause lost motion in the whole system and you may not get full throttle,least that's how mine was.
Steer away from AA for part supply ,besides pelican offer a great service and are closer to you freight wise.
I personally wouldn't buy the linkage new,no sense in cutting up a new one which you may have to do,I payed $30 for a good one and cut that to suit length wise.
Edit,yes get all the bushes @ the same time,cheers.
