QUOTE(cuddyk @ Dec 18 2015, 05:53 AM)
Hi Guys,
While my motor is out and getting cleaned up, I'm wondering if I should have the alternator rebuilt. Power was fine before the teardown, but given how much of a PITA it is to change the alternator with the motor in the car, do you think it's a good "might as well" to rebuild it now? Buy a new one?
I rebuilt mine it was not difficult. It was mainly to do it myself and not so much to save money, it only cost about $25 for the bearings and new brushes. You may also need to turn down any ridges on the commutator, a lathe is required.
You have probably seen this but if you havnt then it may be helpful.
http://www.ephotomotion.com/914engine/alt1.htmlIf you do rebuild yourself then I reccomend that you take it and get it tested before installing.
