mb911
Dec 20 2015, 08:51 AM
My car has the typical rot and I am looking to start fully welding in all the repair panels.. I can see the from how the top fits on the car it's not square. The roll bar is offset from the windshield. Some of this is probably due to an accident that I can see the car was in at one point..some is rust.. I believe the measurement is suppose to be 25 1/8 and there is a diagonal measurement as well.. My questions along with measurement s is exactly where is this to be measured so I make it right previous to all of the welding
914Sixer
Dec 20 2015, 08:55 AM
All the measurement information is in the top right hand corner of forum under 914 Info
cary
Dec 20 2015, 09:34 AM
http://www.914world.com/bbs2/index.php?sho...;hl=measurementThis covers the X measurement.
You need the Y to determine if the windshield is tweaked. This determines if the body is square without the windshield frame in the equation.
mb911
Dec 20 2015, 09:44 AM
Awesome thanks.. Okay so what persuasions methods have all of you used? Ratchet straps, portapower, turnbuckles, come a longs?
jmill
Dec 20 2015, 10:04 AM
Verify all measurements before you pull or push things around. I had Rick (rick 918-s) awesome guy btw, come by and help me. Turns out mine only needed the windshield frame straightened out. I had a door latch that was bad that led me to think body was tweaked. Without Rick, I may have tweaked my car rather than straightening it.
I used a BFH, turnbuckle and Rick's fancy tool to move stuff around (that's Rick in the pics). You may have seen these if you read my sig thread.
Dec 20 2015, 10:29 AM
QUOTE(914Sixer @ Dec 20 2015, 06:55 AM)
http://www.914world.com/specs/914info.php
rick 918-S
Dec 20 2015, 07:08 PM
Make a set of adjustable braces. I use the top latch as a mount rather than the seat belt bolt on the targa bar. The seat belt bolt threaded mount can and does flex.
