1bad914
Mar 14 2005, 06:28 PM
Took the 327 block and heads to the machine shop last Friday. Took the crank over today, the good news is the heads are not cracked, guides are straight and no warpage. The medium to bad news is the cylinder walls are .006-.009 out at the top. Most ring manufactures recommend boring anything over .007, so I'm having him bore it .030 over. A slight increase in displacemnet, but brings me peace of mind. My fear is the stock hp is 300, between the bore, Wieand intake and Holley 650 carb my ponies will increse to much for the stock 901. Good thing I have extra 901's.
TravisNeff
Mar 14 2005, 06:36 PM
That sounds like a rev monster. What kind of cam are you going to run? single or dual plane intake?
1bad914
Mar 15 2005, 06:18 AM
HP is at the crank, you are correct, HP at the wheels will be much less. The machinist is recommending stronger springs on the heads.
The cam is still a toss up, why will I tire of the hotter cam, to much lope at idle or ...??? I'm not really looking at a big difference, it claims to come on at 2500 to 5000 rpm.
I got used to driving like that when I had my Karmann Ghia with a 150 hp motor and a stock trans, hook up and then put your foot down, I only dumped the clutch on that car once, it wheel hopped so bad that the engine tin bent...it shocked a lot of people, they were amazed that a Ghia could wheel hop.
Give me some ideas on cam specs? I'm looking @ 224/224 @50.
The Wieand Stealth is a dual plane intake.
