For the D-Jet setup is has to be the R-V-IE distributor
thieuster
Dec 21 2015, 01:25 PM
The seller is a Dutch company and has been around for a few years already. There's even a brick and mortar shop. No iffy internet sales. You don't have to worry about that.
I have a 123Ignition in my Triumph TR. Installing was a quick job: took less than 15 mins. Most important is the fact that you set the static timing correctly: Be sure you understand the advance/rpm data before you remove your old ignition!
A more expensive version of the 123 gives you a USB portal with the possibility to 'learn' the module how to 'behave' at certain rpm.
Finally: when you need help (language, shipment to the US) just let me know. After all, I'm Dutch; I can pick up the phone to ask questions etc. I'll try to help you if needed!
Menno
luskesq
Dec 21 2015, 01:48 PM
It will likely fit but are you sure it has trigger points? I didn't notice that in the description. Kinda necessary for the stock D-jet.
Keith
thieuster
Dec 21 2015, 02:46 PM
QUOTE(luskesq @ Dec 21 2015, 08:48 PM)
Keith
I can give 'm a call tomorrow ( nearly 10 PM here at the moment)
Menno
r_towle
Dec 21 2015, 04:09 PM
QUOTE(thieuster @ Dec 21 2015, 03:46 PM)
Keith
Menno
Please do call and ask about djet comparability. It would be nice to have a tunable advance curve
JamesM
Dec 21 2015, 06:28 PM
QUOTE(luskesq @ Dec 21 2015, 12:48 PM)
Keith
I was wondering the same thing so I looked through the install instructions
There are two extra wires "yellow" and "White" that get attached to pins 1 and 3 on the "Bosch connector" on d-jet models, so it looks very likely that they made an electronic replacement for the injection points. If this is what it looks to be then this is beyond awesome given the injection points are the one thing we haven't had a source for.
Its digital and has adjustable timing curve to boot. This is seriously exciting.
Millerwelds
Dec 21 2015, 06:34 PM
I previously posted this in another forum. It does have a djet version that has some kind of electrical /light/pick up to trigger the points.
Should be a vast improvement over the 40 year old stock dizzy with wobbly shaft and worn trigger points. Even compared to magnetic point options.
QUOTE(Millerwelds @ Nov 5 2015, 04:34 PM)
Someone help me out here. Looks like stock 2.0 74ish djet setup. Old distributor he shows has trigger points for fuel injection. Someone tell me how the new one is triggering the fuel injectors?
Except the trigger points require 3 wires - a common and 2 poles. Not sure how this works with only two trigger point wires, and then a disconnect connector to the harness is needed.
Mueller
Dec 21 2015, 08:19 PM
Electronic triggering of the injectors has been done before....I installed a setup in a Mallory like 10 years ago, I didn't get much interest at all and didn't it pursue any further than the setup in my car.
With the popularity of EDIS and MS gaining traction it seemed like a dead end project at the time.
Old Yella
Dec 21 2015, 09:04 PM
Precious, I wants one.
Now they just need to do a TPS
DRPHIL914
Dec 21 2015, 11:09 PM
This is very cool, can't wait to hear back about ow it works for you. Maybe next we'll have someone able to engineer a better MPS!! Until then I'll rebuild a couple.
thieuster
Dec 22 2015, 02:36 AM
First thing this morning, I contacted the owner of the LeenAPK website. Leen (Leonard in English) was very informative.
First: he ships to the USA. Shipping costs are 28 euro. You can order the item from his webshop.
Second: you need the 'E' version of the dizzy - as explained and shown in the YT video.
Third: this E version is not available as a tuneable dizzy. So, not USB on this one. Reason: space inside. The trigger mechanism (magnetic with small coils according to Leonard) takes up too much space for an interenal USB portal.
I have a 123 on my Triumph and I am a happy customer. Car starts on the button and idles very smoothly. The main feature of the 123 is the fact that this dizzy works perfectly at high revs. A Triumphs has a low-revving engine a 914's engine however will benefit more from the high revving feature.
Italian Auto Parts, Inc 5579-B Chamblee Dunwoody Rd Ste 322 GA 30338 Atlanta tel: +1 678-637-5103 fax: +1 914-829-9018 info@mrfiat.com www.mrfiat.com
thieuster
Dec 22 2015, 09:40 AM
Given the current Dollar vs Euro exchange rate, it might be a good idea to buy it in Europe...
Menno
JamesM
Dec 22 2015, 11:48 PM
QUOTE(Jeff Bowlsby @ Dec 21 2015, 06:58 PM)
QUOTE(JamesM @ Dec 21 2015, 04:28 PM)
Its been a while since I dissected d-jet, but the common is most likely +voltage which this distributor already has a source for. I dont actually know that it is what they are doing here, but i could see it working.
nordfisch
Dec 26 2015, 02:55 PM
QUOTE(JamesM @ Dec 23 2015, 06:48 AM)
Hi, the lead in the middle is ground (earth). Bosch did this because they tried to isolate all the grounds of the system from the 'engine ground'. Reason for this was: When the 'motor-ground-lead' was broken or in incorrect order all the electric stream would flow through the D-Jet-components and destroy them especially when starting.
One thing to add: You must take care of fitting the contacts to the correct leads. When you interchange them, the engine will run quite normal, indeed - but injection is at wrong timing, suboptimal setup...
Regards Norbert
StratPlayer
Dec 26 2015, 09:13 PM
Thanks for that info...
DRPHIL914
Dec 27 2015, 10:32 PM
Did you order one yet?
StratPlayer
Dec 28 2015, 12:53 PM
No not yet...
StratPlayer
Jun 10 2016, 02:20 PM
It's on its way, order right from the company that makes it,,, it's in the NL.. Hoping I have it next week some time.
Millerwelds
Jun 10 2016, 02:31 PM
Sweet. Super anxious to hear how you like it. I saw an update from them and they now have a bluetooth model where you can use your phone to 'tune' to some degree and it has a real sweet anti theft concept built in where you have to punch in a code on your phone for it to work so the car can not be started without it. Super cool till your phone is dead....
jim_hoyland
Jun 10 2016, 03:06 PM
Very cool, let us know how it works out for you
StratPlayer
Jul 7 2016, 03:06 PM
It's being installed today, pics and a write up to follow.. One thing we discovered was I had a 1.7 distributor running in my car.
mgp4591
Jul 7 2016, 03:12 PM
QUOTE(Millerwelds @ Jun 10 2016, 02:31 PM)
That's why your car comes with an 'accessory socket'!!
StratPlayer
Jul 8 2016, 04:15 PM
I just picked up my car with the new 123 distributor in it and the tangerine racing shift kit installed. The engine is a 2056, org. cylinders bored out to 96mm, Keith Black pistons, Hastings rings. Before the new distributor was installed, the car would hunt at idle, couldn't find any vac. leaks any where. The engine would have a hesitation in it once in a while. Hard to adjust the idle. New distributor installed, no more hunting at idle, no more hesitation what so ever, idle stays exactly where you set it. Great product for the D jet folks that are using a 40 year old distributor. NO trigger points..........
The car was getting very sloppy shifting, that's over.. Car shifts better than new, no more hunting for gears....
I'm very happy with these upgrades, especially the 123 distributor.
Eric Shea from PMB will be doing a write up with pics on the distributor install.
I'm a happy camper.
Millerwelds
Jul 8 2016, 04:18 PM
Thanks for the feedback!
StratPlayer
Jul 8 2016, 04:20 PM
The install is easy, we set the curve setting at 4, engine runs like a top.
Millerwelds
Jul 8 2016, 04:39 PM
QUOTE(StratPlayer @ Jul 8 2016, 03:20 PM)
Yeah the more I researched it I could tell it would be a vast improvement over a 40 year old dizzy and a huge plus getting rid of the trigger points.
JOEPROPER
Jul 8 2016, 04:43 PM
I'm anxious to see the pics and write up on this product. Nice to hear that your upgrades were a success and worth the $ and effort.
rhodyguy
Jul 8 2016, 05:56 PM
Does this distributor require a vacuum signal?
StratPlayer
Jul 8 2016, 10:44 PM
There is a vacuum port on the distributor..
siverson
Jul 8 2016, 11:09 PM
Anyone know if this distributor can be used on a six with the CDI box, or does it replace the CDI/coil with a different coil?
-Steve
Mueller
Jul 8 2016, 11:12 PM
The tuneable setup they have is pretty cool, too bad so pricey!
DavidSweden
Jul 9 2016, 01:38 AM
QUOTE(StratPlayer @ Jul 8 2016, 02:20 PM)
I looked at the installation instructions but I didn't find any information regarding choosing the appropriate curve.
How do you know which curve to choose?
StratPlayer
Jul 9 2016, 09:03 AM
In the install instructions there is a list of dizzy numbers for the 914. When you pull your old dizzy, check the numbers and compare with list on the install instructions.
rhodyguy
Jul 9 2016, 10:46 AM
as they seem to offer units for 356s and 912s, i wonder if they have one for carbed T-4s. mallorys didn't come cheaply either and when the module craps out, it's spendy.
Mueller
Jul 9 2016, 12:38 PM
QUOTE(rhodyguy @ Jul 9 2016, 09:46 AM)
These too are electronic and can fail, do they offer replacement components or do you need to send the entire unit back if you let out the smoke?
StratPlayer
Jul 10 2016, 05:55 PM
QUOTE(rhodyguy @ Jul 9 2016, 10:46 AM)
