mrholland2
Dec 23 2015, 03:10 PM
Has anyone done this????
Cracker
Dec 23 2015, 03:12 PM
Why? is your cable broken? One of the nice things about old P-cars is how simple they are - you want to complicate it? Hmm?
T
mrholland2
Dec 23 2015, 03:15 PM
I'm not a fan of the cable routing etc. Plus the tub I'm using (all painted etc) seems to be missing some routing/mounting points for the cable. Plus, yes. . I wanna be more complex! And deep. . and brooding LOL
QUOTE(Cracker @ Dec 23 2015, 01:12 PM)
T
Cracker
Dec 23 2015, 03:24 PM
I believe my old Boxster S had an electric hood release. In the event the battery died there was a jumping terminal in the cockpit to power the circuit (and get to the battery). Just plan for that...
T
jmill
Dec 23 2015, 06:45 PM
I wonder if a power door lock actuator has enough power to pop the hood? If so it would be cheap and easy.
Mike Bellis
Dec 23 2015, 07:30 PM
QUOTE(jmill @ Dec 23 2015, 05:45 PM)
No. You need a solenoid.
alfadoc
Dec 23 2015, 08:36 PM
Snag a hatch release solenoid off of a 944. Cheap enough, and keeps it in the family.
jim_hoyland
Dec 23 2015, 10:05 PM
QUOTE(alfadoc @ Dec 23 2015, 06:36 PM)
Got a pic of one ?
thelogo
Dec 24 2015, 12:19 AM
[quote name='Cracker' date='Dec 23 2015, 01:12 PM' post='2280763'
T
[/quote]
That's just like the a-4 shyhawk
Heinmans hot rod , simple light and responsive
A philosophy never to be gotten away from
And I forbid any one to put in keyless entry in a 914
Unless that means you away just leave the door unlocked
Mike Bellis
Dec 24 2015, 12:56 AM
QUOTE(thelogo @ Dec 23 2015, 11:19 PM)
I never lock my doors...
horizontally-opposed
Dec 24 2015, 01:15 AM
I've always been amazed by the amount of effort my front trunk latch requires. Suspected there's something off for a long time, but it's never gotten worse. Or perhaps it has.
Any ideas? I'd way rather fix the cable setup than adapt an electric system...
EdwardBlume
Dec 24 2015, 06:57 AM
QUOTE(Mike Bellis @ Dec 23 2015, 10:56 PM)
Sometimes I inadvertently leave the barn door open....
EdwardBlume
Dec 24 2015, 06:59 AM
QUOTE(horizontally-opposed @ Dec 23 2015, 11:15 PM)
Same thing in my 74s. The only smooth front hood release I've ever seen is uninstalled in my hand. I figure it's the cable length and latch pressure.
rgalla9146
Dec 24 2015, 08:11 AM
Keep in mind that there is a hole in the front closing panel to operate the latch if your hood cable (.....or solenoid) fails.
But........you have to remove the front bumper to use it
NeunEinVier
Dec 24 2015, 01:25 PM
QUOTE(jim_hoyland @ Dec 23 2015, 10:05 PM)
Got a pic of one ?
Pretty serious motor and gear reduction to pull the cable.
http://rennlist.com/forums/attachments/944...ealease-002.jpg
Chris Pincetich
Dec 24 2015, 02:58 PM
QUOTE(RobW @ Dec 24 2015, 04:59 AM)
Even with a new cable from 914rubber, removed and cleaned/lubed the latch, and it takes a strong pull to get the front to release.
Mikey914
Dec 24 2015, 03:47 PM
QUOTE(Chris Pincetich @ Dec 24 2015, 12:58 PM)
Usually it's not the cable t g at some the issue, it's the guide tube being cracked.
GeorgeRud
Dec 24 2015, 04:12 PM
I'm sure you could apply some lubricant (silicone, graphite, white grease?) to the cable sheath, but releasing it from the latch and seeing how much friction is present in the cable itself may be helpful. The latch itself should be cleaned, lubricated, and carefully adjusted to keep it working properly.
It shouldn't take Hurculean strength to open the front trunk latch if things are properly adjusted.
Mike Bellis
Dec 24 2015, 04:41 PM
They are tough to pull due to the spring tension and the gasket tension.
I run hood pins.
mrholland2
Jan 4 2016, 06:15 PM
But giant "American" cars have really long cables and so forth, but I've never had one as tough as this. I'm okay with manual if I can get it where it would be of modest resistance. Right now, I'm gonna nickname the hood release "Borg".
