QUOTE(80cap @ Dec 27 2015, 02:38 PM)
I about to reinstall the a pillar trim and rubber. I see the factory used some kind of sealant between the a pillar trim and body work. Is this RTV or some other adhesion.
One step at a time!
Brian
It probably was RTV or butyl originally. Those strips can be hell to remove.
DumDum is probably a better choice today, it will allow easier adjustment later.
But it should be flattened so that the trim will lay flat.
