Early Rivieras, with smooth lip. Proper backspacing for Porsche 914. Just spent hours polishing them, but could use respray on black paint. No major rash, minor rubs cleaned off. Tires are out of date, but I drove on them last year, plenty of tread. Can use for a project or for final testing to get car streetworthy. Bridgestone Potenzas 205 x 55 or 60 x 15. These typically fit on narrow body cars. Fit on my 74 and 75 with no known fender rolling. $250 for the set, you pick up in SoCal Lake Forest/Irvine/Mission Viejo area. Los Angeles area delivery negotiable.
Chrome ball seat lug bolts (16) for them, new. $30
I Also have:
1. Driver side door, early, with all glass. $50/obo Good cond, no dents, almost no rust, just a little on bottom edge at weatherstrip which is common. (calif car), orig phoenix red (orange) No handles, door latch, card, or mirror. Door works fine, but didn't match my car's year. window mechanism was also working when on car. What you see as dark areas in the pictures is old glue or paint, not rust.
2. Rocker panels, small rust thru near jack pt. has been welded to repair, right only. two avail. $35 each, or $50 each if I weld repair the rusted spot.
3. Seat cores, 2 avail, no bottom cushion, some missing back cushion.. recover and make a desk chair like I did! $45 ea
4. seat tilt mounts with slider rails $35 ea.
5. Tail light lenses, so-so driver quality, several have a lot of crazing, one has a couple 2" cracks, one missing one of three mounting posts $20 a pair.
6. Two right lamp assemblies/housings. Good working order, some bulbs too, no melt thrus. a couple spots on the weather strip channels has chips out. driver quality lens comes free if I still have them. $30 ea
7. rear brake rotors, 4 lug, used but life left. $20 a pair.
18. Fog light grills, both driver side. $15 each. Chrome a little deteriorated and greenish, one has top corner broken near screw, but mounts just fine, hardly noticeable for a driver quality. Other has epoxied fixed crack along bottom rail.Click to view attachment Click to view attachmentClick to view attachmentClick to view attachment[attachmentid=533
472]
