Pictures to be posted later.
These pedal sets have a metal tab welded to the accelerator crank to work with the hand throttle lever as as used on 914-6's and now offered by 914 Rubber.
I am now offering pedal sets for use with the 914 Rubber hand throttle setup. This setup is a must for any carbed four or six engine for more controlled cold weather warm up.
NOT INTENDED OR RECOMMENDED TO BE USED AS A CRUISE CONTROL. Use as such is entirely at users risk and any and all damage that occurs is the fault of the user.
DON'T DO IT!
I have enough parts to build two pedal sets with more to be available soon.
Price is $10 more than the standard pedal set or $225 shipped in the U.S. The price is based on the return of a usable core pedal set that includes the brake light switch, good accelerator crank and brake rod.
http://shop.914rubber.com/914-6-hand-throt...or-AX-914HT.htm
