mountainroads
Dec 29 2015, 03:12 PM
One of the electrical leads on my (apparently somewhat rare) rear window defroster has broken off where it attaches to the glass. I'd like to make functional again, but not at cost of cracking the glass. I'm wondering if enough heat can be applied to bond a dab of electrical solder and then reattach the broken lead, or if that is risking a crack. If so, then what is the preferred repair technique? Input appreciated. Thanks.
- MR
Mark Henry
Dec 29 2015, 03:48 PM
I think every Canadian 914 had them...mine does and it was originally sold just north of you in Vancouver, BC.
NeunEinVier
Dec 29 2015, 03:55 PM
mountainroads
Dec 29 2015, 04:05 PM
Thanks much for the tips, Neun and Cairo (below). Videos and suggestions appreciated.
- MR
Cairo94507
Dec 29 2015, 04:10 PM
I would consult a glass shop and see if they have any suggestions.
mountainroads
Dec 29 2015, 04:15 PM
QUOTE(Mark Henry @ Dec 29 2015, 01:48 PM)
Good point and that makes sense that it would almost be a standard delivery item in Canada. The apparent "rarity" comes from this being a -6, and I believe very few (if any ??) were imported directly into Canada. This car was originally purchased in Everett, Wa. and has remained in-state for it's entire life. Washingtonians appreciate a good defroster too. More for the humidity than the cold
- MR
76-914
Dec 30 2015, 09:44 AM
IIRC, rear window defrosters are available in an aftermarket kit. Scrape off the old and apply the new. I looked into them a few years back for my K Ghia. I can not attest to their effectiveness.
Hank914
Dec 30 2015, 12:04 PM
Kinda off topic but has anybody done a rear window mod that raises and lowers the rear window, like some Honda or other pick up trucks? I want more ventilation, and am thinking kinda like the soft window 912s. Not sure where the window would "roll" down to, or if I'm all messed up
but I would love a back window in the 914. Thoughts?
JeffBowlsby
Dec 30 2015, 12:14 PM
Go ahead...pop that rear window out and drive around for about 2 minutes and tell us what it does to your hearing.
sixnotfour
Dec 30 2015, 12:48 PM
WHAT ?? he said...
maf914
Dec 30 2015, 03:25 PM
The fixed rear window acts like a wind blocker, reducing the wrap-around turbulence from the wind directed overhead by the windshield. I always liked that characteristic. It's interesting that almost all modern convertibles, especially two-seaters, are now equipped with some form of wind blocker behind the seats.
Valy
Dec 30 2015, 07:08 PM
There is a repair kit for those things. It's a conductive paint that you paint on to repair contacts. You can glue the contact with epoxy to the glass and then paint over the connector and trace on glass remake the contact.
SLITS
Dec 30 2015, 10:46 PM
Silver Conductive Epoxy (cold solder)
dangerranger01
Dec 31 2015, 01:45 AM
You should keep this thread updated....I'm going to be in your boat here soon with my rear defrost so i wouldn't mind some guidance...
EdwardBlume
Dec 31 2015, 01:12 PM
QUOTE(dangerranger01 @ Dec 30 2015, 11:45 PM)
I 3M'd the rear window in really well, so hopefully age and weather will move things over towards taking it back out.... it was tricky getting it in with the bar in the way....
