siverson
Dec 30 2015, 11:34 PM
This is way off topic, and I'm sure the answer is going to be "run away", but I've been browsing the MK1 GTIs for a while and this one has popped up:
http://forums.vwvortex.com/showthread.php?...oject-Grey-HairSeems like a great start, and pretty cheap. But... how hard would it be to get it registered in California? Anyone have any ideas?
-Steve
Mike Bellis
Dec 31 2015, 12:33 AM
It needs to have all the smog equipment from the donor car. From the fuel tank to the engine and exhaust.
Then you need to go to a BAR approved referee station and have them certify the swap.
Mike Bellis
Dec 31 2015, 12:34 AM
Based on the VW Vortex ad, it will be expensive to make it smogable...
Martin Baker
Dec 31 2015, 12:36 AM
I have owned several MK1 GTI and Sciroccos. I love those cars. While I was in Germany I had an 80, and an 83 Pirelli Edition. Also had one of the US made 83 GTI's. I recently sold my 1980 MK1 Scirroco S.
MB
matthepcat
Dec 31 2015, 01:01 AM
Actually I read the build thread. It's a diesel chassis.
NO SMOG!
Buy it! It's sweet!
http://forums.vwvortex.com/showthread.php?...-grey-hare-quot
siverson
Dec 31 2015, 09:15 AM
> NO SMOG!
I don't think that's how it works in CA...
-Steve
siverson
Dec 31 2015, 09:18 AM
> Does my vehicle qualify for a smog exemption?
> Smog inspections are required unless your vehicle is:
> Diesel powered 1997 year model and older
Oh hmmmm... this is all so new to me...
-Steve
Andyrew
Dec 31 2015, 09:36 AM
QUOTE(siverson @ Dec 31 2015, 07:15 AM)
> NO SMOG!
-Steve
Thats how it works in CA
From DMV Website.
"Currently, smog inspections are required for all vehicles except
diesel powered vehicles 1997 year model and older or with a Gross Vehicle Weight (GVWR) of more than 14,000 lbs, electric, natural gas powered vehicles over 14,000 lbs, motorcycles, trailers, or gasoline powered vehicles 1975 and older."
Buy it! Put in a GT28RS Eliminator turbo, Get it tuned by a buddy of mine and have 300hp!
jmill
Dec 31 2015, 09:46 AM
Man, I love the MK1 GTI's. Tried to get my 16 year old son to get one instead of a Honda. I used to race against the GTI in SCCA. It was crazy how the inside rear tire would always lift a foot or so in the air around every corner.
matthepcat
Dec 31 2015, 11:31 AM
Yea, back in high school I had buddies that would buy the diesel K5 Blazers and yank the drivetrain for big block V8's for off-road rigs. This is back when smog year in CA was still 1964 or something.
Mike Bellis
Dec 31 2015, 06:25 PM
Here's the problem...
To import it into California, DMV will do a VIN inspection. During this inspection they will discover the engine swap and you will be fuched. I have imported twice and they always look at the engine.
If it were already in CA then I would say go for it.
Andyrew
Dec 31 2015, 06:37 PM
You could have someone from a non smog county register it under their name and then transfer ownership. Nothing illegal about it and it would bypass that problem...
DBCooper
Dec 31 2015, 07:21 PM
Worst case pull the engine, trailer it to get the VIN verified, then take it home and put it back together.
Mike Bellis
Dec 31 2015, 08:31 PM
QUOTE(Andyrew @ Dec 31 2015, 05:37 PM)
That will not get you around the DMV VIN inspection. Every vehicle imported is required to have the VIN inspection. There is a slim chance that AAA might be able to do it if you are a member. CHP can do it but they might also discover the engine swap.
This is a no go... Not worth the headache... Or the $$$ it will cost to swap back in a diesel engine if caught...
Mike Bellis
Dec 31 2015, 08:33 PM
QUOTE(DBCooper @ Dec 31 2015, 06:21 PM)
That is a good option and should work. But a little suspicious to DMV. This is not the first diesel car with a gas engine swap.
damesandhotrods
Dec 31 2015, 10:35 PM
It has been a while since I was around anyone with a pre-1997 Diesel but as I remember it Diesels did not require smog inspections. But they were required to be inspected to verify it was still Diesel powered…
strawman
Jan 3 2016, 12:22 AM
I swapped a 1997 VW Passat TDI into my 1993 Eurovan Westy, and just got it BAR'd. No more smog!
I'm now swapping an S52 out of a 1998 BMW M3 into my 1996 BMW 318ti(replacing a BAR'd M52 out 0f a 328i). Should be a real monster. I need to stop these "side projects" and finish the turbo Suby into my 914...
