QUOTE(MarkV @ Jun 12 2003, 09:17 PM)
I am sure someone will chime in but I think high lift short duration cams are designed for high RPM motors. Long duration shorter lift cams make power lower in the RPM band. Or is it the other way around?
shorter duration cams make power lower rpms but and are more fuel efficient but can't move the charge into the cylinder as efficiently at high rpms. this is your typical type 4 fuel injection cam. it has a high vacuum due to less overlap.
as you increase duration, you gain high rpm ability but sacrifice low end, which is why you get the camshaft "lumpy" idle. the longest duration cams have the worst idles, but coolest sounding, to a point.
lift is how much the valve is open, but to get more lift you almost have to increase duration to keep the "hill" the lifter climbs from getting too steep, which would wear more rapidly.
Another variable is valvetrain weight and spring rates. the lifter,pushrods, rockerarms, and valves have mass. the more mass, and the higher speed the mass is moving when it jumps the hill of the cam, the more spring pressure is needed to keep the valves from going "airborne", which is called valve float and is the clatter you hear when you rev the engine higher. more spring pressure also means more load on the components, and more wear.
more or less
So the trick is to decide what is most important to you and get the cam that supplies it, high rpms and power, low end torque, fuel efficiency and emissions, reliability, We're dealing with a lot of sh*t here.
Add to that we have to completely disassemble the engine to change the cam if we make the wrong choice, and doing your homework on the cam is pretty important.
my 2 cents.
