BillC
Dec 31 2015, 12:32 PM
I'm in the process of cleaning/painting my engine tins and replacing all of the vacuum and fuel hoses, and found a problem -- the rubber "Y" that connects the auxiliary air valve and the decel valve to the intake plenum is cracked. The part has the number 022-133-083 on it.
I googled that part number, and found a few places selling a version with a "D" suffix. Unfortunately, it turns out to be the wrong part (too long, holes too big). Does anyone know of a source for the correct part? I tried searching the 914Rubber site, but couldn't find it (site is kinda hard to search). I've also sent Mikey914 a PM, but if he's travelling it might take a while to get a reply.
I might be able to repair the part by coating it in silicone, but I'd really rather just get a new (and correct) replacement.
Thanks!
rgalla9146
Dec 31 2015, 12:49 PM
QUOTE(BillC @ Dec 31 2015, 01:32 PM)
Thanks!
Post a picture.
stinkindiesel
Jan 1 2016, 02:42 PM
I've had no luck finding one of those either. Right now I'm running a standard 9mm hose with a 5mm hose barb cut into the side to form the Y. Apparently, this is a single year/engine piece, so isn't being reproduced. I'm not even sure any of the VW 411 or bus applications used it.
Gary
Mikey914
Jan 2 2016, 12:46 PM
I'll make these. As we all can use them. Just need a suitable sample to start with.
mark
Dave_Darling
Jan 2 2016, 07:34 PM
You can make something that will work out of plumbing supplies. It may not be right, but if you're only concerned with functionality it should do.
--DD
BillC
Jan 3 2016, 12:55 PM
Here's a pic of my old one, compared with a new one that's obviously too large. The graph paper is 1/4" squares, so you can get an idea of scale.
JeffBowlsby
Jan 3 2016, 03:59 PM
Silicone the small metal tube in there as a temp solution?
