QUOTE(whizone @ Jan 2 2016, 12:52 PM)
got the main seal and Oring but dont get the end play adjustment? the old flywheel bolt tops were shiny from rubbing the old clutch disc. Does that have anything to do with the end play? thanks.
QUOTE(Mark Henry @ Jan 2 2016, 10:55 AM)
You will also need to measure and adjust your flywheel end play, plus new main seal and flywheel Oring.
You need to make sure the new flywheel you are going to use has not been ground down as much as the old one.
There is a spec that shows the difference between the mounting face of the,pressure plate and the friction surface of the flywheel.
