First - some 914 A/C 101 -
There were only 2 types of dealer installed A/C - & some good & some bad aftermarket non-official A/Cs out there. Any of the later aftermarket ones - with the possible exception of today's higher quality Sanden, RetroAire, AutoAtlanta, etc. units - were not of the same quality & not generally offered by Porsche+Audi dealers (some did do so IIRC), but rather were installed by local auto air shops, Sears, Monkey Ward's, etc. - & those I'd shy away from.
Only the VPC & DPD A/C's were approved for sale/use by Porsche for dealers to install in both 911/912 & 914 cars - as were a set of dealer installed options & accessories.
Unlike today - where you can get just about anything on order from the auto mfgrs./factory - back then in the 50's, 60's & early/mid 70's the dealers installed most options on cars -
not the factories for any make. Heck - Porsche only started their own new free standing USA Porsche+Audi dealerships in 1969 (in time for the `70 MY when the 914/4 & 914-6 were introduced), & previously sold their Porsches in the US on VW dealership floors, & so many VW dealerships dropped Porsche & Audi to save the expense of building another facility!
So contrary to some unaware of this fact about dealer installed options/accessories, a dealer installed period option is considered correct & generally adds value or at least doesn't take away from it. Likewise, an original dealer installed unit, since updated with a modern Sanden or similar rotary compressor &/or updated to R134 shouldn't change that value, & may even be more desirable since it provides the chill without robbing more than 1-5 HP, vs 7-12 HP on the old Yorks.
A dealer installed option or accessory from the pre-1980s period is just NOT the negative "add-on" attitude, that it is for more modern cars, with anyone knowledgeable in classic cars. This is true not only for A/C, but also for radios & tape players, leather & wood Porsche crest shift knobs, "PORSCHE" side stripes, & all sorts of other goodies available from the dealers from the Porsche approved brochures of the VPC offerings.
Also, the dealers back then would do a respray of the cars to suit a buyer 7 if it wasn't selling well in a particular color, & they could do a side-by-side full interior swap on 914s & 911s for a buyer wanting a different interior color, & regularly stripped optional items off of cars to suit a buyer - leaving the stripped car short of equipment listed on its window sticker. My 73 914-2.0 not only was resprayed from L80E Light Ivory (white) to Sahara Beige, then Gold before being first sold; & it had its fog lights/grills/dash-switch & Fuchs 2L alloy wheels stripped by the dealer before the OO got it (I'm the 2nd owner).
However, a current owner added to dealer spec unit or later "modern" unit is more dicey, as it may or may not add value, even if they probably work better than the old ones from back in the day.
Of course, as you can see from the responses in here so far - cars are a highly personal choice, so the + or - will ultimately be in the eyes of a particular buyer.
A well done A/C dealer installed (or resto of same) which is operational & in great condition should add some value in many buyers' & appraisers' minds - while beat up, inoperable ones are just dead weight & detractors.
I just had the discussion in Nov./Dec. with the Hagerty guys, which led to the change for A/C adding 10% - vs. some other incorrect value add items which Hagerty previously listed under the "Notes" section (e.g.; 5-speed transmission!?
). I'm not sure that 10% is the correct number, but that's what they came up with so far.
Also of note, I have had no discernible loss of cooling power on either my 85 BMW 325e nor 88 VW Westy when we updated both of them to R134 Freon, at the time when their respective OE compressors died. So I see no reason to stick with R12 - especially at now $100+ per unit! So don't hesitate converting to R134 - especially if you're changing to the Sanden or other more efficient rotary compressor &/or otherwise updated the A/C system.
As for the pros/cons of the VPC & DPD systems - both used the same York compressor which robbed 7-12 HP when running, but the later DPD was an improvement in terms of operation & fitment. Both were apparently designed by the same engineer(s) - initially for Volkswagen Products Corp. (VPC), who also produced (or contracted for) a whole line of Porsche options in the US/NA marketplace (IIRC DPD was also sold under the VPC accessories & options brochure program).
The VPC used a big rectangular evaporator coil housing in the spare tire well of the front trunk, which forced the spare to be mounted several inches higher, so the floor board was higher & robbed trunk space up front, as well as having the under dash A/C controls off-center in the dash with only 4 outlet vents center & right/passenger.
Whereas, the improved DPD had a smaller evap. coil with a conical housing, which allowed the spare to sit down over it & within the original front trunk floorboard level, thereby preserving trunk space. Additionally it added another outlet vent closer to the driver/steering column & centered the controls under the heater/ventilation dash controls & thereby closer to the driver's reach - both improving the A/C's effectiveness & ease of use. There were also supposedly other engineered improvements to the DPD system (supposedly the AA modern A/C system was designed by the same engineer as yet another level of improvement).
These visible differences in the front trunk & under the dash is the best way to identify which - VPC or DPD - & pix of them are in the info at Jeff Bowlsby's 914 website. Jeff Bowlsby's 914 website has online copies of the Porsche+Audi dealer accessory/option sales brochures, DPD & VPC install guides, owner manuals, etc. FYI.
Also, additional sheet metal exposure areas for the tin worm are other concerns with the dealer, aftermarket & modern A/C installs (& more so with aftermarket hacks of the 70's & 80's).
Now as to wanting or needing A/C - well my 914 was my DD for about 10 years & 130,000 miles from 12/75 to 5/85, before being sidelined in my garage since (another story), &
I surely would've LOVED to have had A/C in my car back then, but they were & are still fewer & far between, & I bought mine financed used on a tight "first job out of college" budget at 3 years old, after a 8 month search of a dozen or two 70-74 914s (& even trying the new 76 2.0 at dealers, which had a permanent 10-12 HP loss due to increased smog controls over the 73-74 2.0s), some 40+ years ago now.
It would've saved me having to remove ties, roll shirt sleeves up - & even sometimes roll suit pant legs up, & blast the fan with the old "Sears 265 A/C" on (roll down 2 windows & drive 65, for the uninitiated) when it was 90, 100 & even 110-120 sometimes!
.... & we don't have your eastern, nor midwestern & southeastern humidity!!
When you have to drive a 914 to work, meetings, site visits, etc. & are expected to be in suit & tie - it just is NOT comfortable in a non-A/C car - 914 or whatever!
It was also a deterrent for the gals who wanted to be cool & comfortable on hot days, as it is now still an impediment for my wife not wanting to be stuck in a hot car some 30 years later!
So I have to disagree a bit with some of the above naysayer & "just toughen-up" comments, & even today I'm still a bit on the fence as to whether to retrofit an updated period correct DPD/Sanden/R134 system - even if it won't be my DD in the future, but now in my 60s I'd still prefer the option to turn the A/C dial, be cooler & put up with a couple less HP gitty-up!
Bottom line - you make the decision that fits you, & pick the best 914 you can find & afford - whether with or without A/C. And if the A/C is non-op, then it's no added value, until & unless youspend the $$s to fix it so don't pay extra if non-op!
Good Luck!
Tom
