Hi Guys,
Wondering if anyone has advice on how to clean up / prep the exhaust ports on the heads for new copper gaskets. As you can see in the pic, it seems like there was a leak that built up some sooty deposits. The engine is on a stand now, but it's kinda tight in there and I'd love to not remove the heads.
I've already used a flat file on the heat exchanger to insure that everything is flush. I plan on annealing the new gaskets and using some permatex ultra copper RTV sealant. Unless you have other ideas as well.
Thanks!
